Asus X200CA Battery Replacement
    1. Asus X200CA Battery Replacement, Keyboard: step 1, image 1 of 2 Asus X200CA Battery Replacement, Keyboard: step 1, image 2 of 2
      • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
      • Remove the black 14.5mm screw from the center of the bottom cover.
      Ask FixBot
    2. Asus X200CA Battery Replacement: step 2, image 1 of 1
      • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
      Ask FixBot
    3. Asus X200CA Battery Replacement: step 3, image 1 of 1
      • Pull apart the keyboard and the bottom cover using your hands.
      • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
      Ask FixBot
    1. Asus X200CA Battery Replacement, Battery: step 4, image 1 of 2 Asus X200CA Battery Replacement, Battery: step 4, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the black 4.7mm screw holding the battery in place.
      Ask FixBot
    2. Asus X200CA Battery Replacement: step 5, image 1 of 1
      • Lift the battery by the tab you removed the screw from.
      • Replace with the new battery, if necessary.
      Ask FixBot
11 other people completed this guide.
Jacqueline Collier
1,119 Reputation
5 Guides authored
USF Tampa, Team S1-G2, Leahy Fall 2017 Member of USF Tampa, Team S1-G2, Leahy Fall 2017
USFT-LEAHY-F17S1G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 142
All Time: 7,839
