Asus W2W-A1 Touchpad Replacement
    1. Asus W2W-A1 Touchpad Replacement, Keyboard: step 1, image 1 of 3 Asus W2W-A1 Touchpad Replacement, Keyboard: step 1, image 2 of 3 Asus W2W-A1 Touchpad Replacement, Keyboard: step 1, image 3 of 3
      • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
      • Unscrew the 2 4 mm Phillips head screws by the battery.
      Ask FixBot
    2. Asus W2W-A1 Touchpad Replacement: step 2, image 1 of 1
      • Remove the panel above the keyboard with a plastic spudger.
      Ask FixBot
    3. Asus W2W-A1 Touchpad Replacement: step 3, image 1 of 1
      • Once the panel is removed, use the spudger to pry out the keyboard.
      • Do not fully remove, for the keyboard is still attached to the ribbon cable.
      Ask FixBot
    4. Asus W2W-A1 Touchpad Replacement: step 4, image 1 of 2 Asus W2W-A1 Touchpad Replacement: step 4, image 2 of 2
      • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
      • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
      • Now you can fully remove the keyboard from the laptop.
      Ask FixBot
    1. Asus W2W-A1 Touchpad Replacement, Front Panel: step 5, image 1 of 1
      • Place your fingers or a spudger between the front panel and the rest of the laptop.
      • Pull upwards gently to detach the side you are grabbing.
      • Repeat on the other side until the panel easily peels off the laptop.
      Ask FixBot
    1. Asus W2W-A1 Touchpad Replacement, Touchpad: step 6, image 1 of 2 Asus W2W-A1 Touchpad Replacement, Touchpad: step 6, image 2 of 2
      • The touchpad should be loosely attached to the rest of the laptop by a ribbon cable.
      Ask FixBot
    2. Asus W2W-A1 Touchpad Replacement: step 7, image 1 of 1
      • Gently pull the ribbon cable out of its socket attached to the touchpad.
      • You are now able to remove the touchpad.
      Ask FixBot
Nolan Schock
501 Reputation
5 Guides authored
Cal Poly, Team 13-29, Maness Spring 2014 Member of Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 96
All Time: 634
