Asus W2W-A1 Fan Replacement
    1. Asus W2W-A1 Fan Replacement, Keyboard: step 1, image 1 of 3 Asus W2W-A1 Fan Replacement, Keyboard: step 1, image 2 of 3 Asus W2W-A1 Fan Replacement, Keyboard: step 1, image 3 of 3
      • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
      • Unscrew the 2 4 mm Phillips head screws by the battery.
      Ask FixBot
    2. Asus W2W-A1 Fan Replacement: step 2, image 1 of 1
      • Remove the panel above the keyboard with a plastic spudger.
      Ask FixBot
    3. Asus W2W-A1 Fan Replacement: step 3, image 1 of 1
      • Once the panel is removed, use the spudger to pry out the keyboard.
      • Do not fully remove, for the keyboard is still attached to the ribbon cable.
      Ask FixBot
    4. Asus W2W-A1 Fan Replacement: step 4, image 1 of 2 Asus W2W-A1 Fan Replacement: step 4, image 2 of 2
      • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
      • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
      • Now you can fully remove the keyboard from the laptop.
      Ask FixBot
    1. Asus W2W-A1 Fan Replacement, Front Panel: step 5, image 1 of 1
      • Place your fingers or a spudger between the front panel and the rest of the laptop.
      • Pull upwards gently to detach the side you are grabbing.
      • Repeat on the other side until the panel easily peels off the laptop.
      Ask FixBot
    1. Asus W2W-A1 Fan Replacement, Touchpad: step 6, image 1 of 2 Asus W2W-A1 Fan Replacement, Touchpad: step 6, image 2 of 2
      • The touchpad should be loosely attached to the rest of the laptop by a ribbon cable.
      Ask FixBot
    2. Asus W2W-A1 Fan Replacement: step 7, image 1 of 1
      • Gently pull the ribbon cable out of its socket attached to the touchpad.
      • You are now able to remove the touchpad.
      Ask FixBot
    1. Asus W2W-A1 Fan Replacement, Protective Cover: step 8, image 1 of 1
      • Unscrew the 3 13 mm Phillips screws on the surface of the panel.
      • Unscrew the 4 mm Phillips screw beneath the panel.
      Ask FixBot
    2. Asus W2W-A1 Fan Replacement: step 9, image 1 of 3 Asus W2W-A1 Fan Replacement: step 9, image 2 of 3 Asus W2W-A1 Fan Replacement: step 9, image 3 of 3
      • There are many different types of screws in this step so make sure to arrange the screws by their different sizes.
      • Unscrew the six 17 mm Phillips head screws on the stands on the back and the 2 "A" screws of the same size adjacent to the stands.
      • Unscrew the two C Phillips head screws on the hard drive panel. There is also one more C screw in the upper right corner of the laptop as shown.
      • Unscrew the eight 8mm lock phillips screws and the screws along the outside of the laptop.
      • Unscrew the three 3mm E Phillips screw and the one 3mm D Phillips screw.
      • Unscrew the 5mm Phillips head screw that lies just above the D screw.
      Ask FixBot
    3. Asus W2W-A1 Fan Replacement: step 10, image 1 of 1
      • Unscrew the two 8 mm Phillips screws beneath the hard drive panel.
      • After finishing this step, flip the laptop over.
      Ask FixBot
    4. Asus W2W-A1 Fan Replacement: step 11, image 1 of 1
      • Everything should now be loose enough for you to start removing the panel.
      • Do not fully remove the panel, for there are still ribbons attached on the inside.
      Ask FixBot
    5. Asus W2W-A1 Fan Replacement: step 12, image 1 of 1
      • Carefully remove the ribbons from the base.
      • Then you can lift the panel to access the components beneath.
      Ask FixBot
    1. Asus W2W-A1 Fan Replacement, Fan: step 13, image 1 of 2 Asus W2W-A1 Fan Replacement, Fan: step 13, image 2 of 2
      • Remove the 3 4 mm Phillips head screws holding down the fan on inside of the laptop.
      Ask FixBot
    2. Asus W2W-A1 Fan Replacement: step 14, image 1 of 1
      • Remove the 4 mm Phillips head screw holding the left panel on the back of the laptop.
      • Slide off the left panel by pulling to the left.
      Ask FixBot
    3. Asus W2W-A1 Fan Replacement: step 15, image 1 of 2 Asus W2W-A1 Fan Replacement: step 15, image 2 of 2
      • Remove the 4 4 mm Phillips screws on the orange cooling system.
      Ask FixBot
    4. Asus W2W-A1 Fan Replacement: step 16, image 1 of 1
      • Gently lift the orange cooling system upward to remove it from the laptop.
      Ask FixBot
    5. Asus W2W-A1 Fan Replacement: step 17, image 1 of 2 Asus W2W-A1 Fan Replacement: step 17, image 2 of 2
      • Disconnect the cable from its socket by pulling up on it gently. It will be revealed beneath the previously removed cooling system.
      Ask FixBot
    6. Asus W2W-A1 Fan Replacement: step 18, image 1 of 2 Asus W2W-A1 Fan Replacement: step 18, image 2 of 2
      • From the front of the laptop, remove the tape holding down the fan's cable.
      • Gently push down on the protective area around the fan as shown to pull the cable through the gap created.
      • Lift the fan out of the laptop.
      Ask FixBot
Emily Mullins
201 Reputation
2 Guides authored
Cal Poly, Team 13-29, Maness Spring 2014 Member of Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 108
All Time: 966
