Asus W2W-A1 Disc Drive Replacement
    1. Asus W2W-A1 Disc Drive Replacement, Disc Drive: step 1, image 1 of 1
      • Use a Phillips head screwdriver to remove the one 3mm screw labeled D on the back of the laptop.
      Ask FixBot
    2. Asus W2W-A1 Disc Drive Replacement: step 2, image 1 of 2 Asus W2W-A1 Disc Drive Replacement: step 2, image 2 of 2
      • With that screw removed, you can now pull the disc drive out of the laptop by pulling on it in the direction that it slides.
      Ask FixBot
Emily Mullins
201 Reputation
2 Guides authored
Cal Poly, Team 13-29, Maness Spring 2014 Member of Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 104
All Time: 751
