Asus Vivobook Q301LA-BHI5T02 RAM Replacement
    1. Asus Vivobook Q301LA-BHI5T02 RAM  Replacement, Back Cover: step 1, image 1 of 1
      • Make sure the computer is turned off.
      • Flip the device over so that the back cover is facing you.
      Ask FixBot
    2. Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: step 2, image 1 of 2 Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: step 2, image 2 of 2
      • Remove the four 5mm Phillips #1 screws from the top of the laptop.
      • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
      • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
      Ask FixBot
    3. Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: step 3, image 1 of 3 Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: step 3, image 2 of 3 Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: step 3, image 3 of 3
      • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
      Ask FixBot
    4. Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: step 4, image 1 of 1
      • Lift off the cover and remove the back cover from the device.
      Ask FixBot
    1. Asus Vivobook Q301LA-BHI5T02 RAM  Replacement, RAM: step 5, image 1 of 3 Asus Vivobook Q301LA-BHI5T02 RAM  Replacement, RAM: step 5, image 2 of 3 Asus Vivobook Q301LA-BHI5T02 RAM  Replacement, RAM: step 5, image 3 of 3
      • Remove the top covering the RAM chips.
      Ask FixBot
    2. Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: step 6, image 1 of 3 Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: step 6, image 2 of 3 Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: step 6, image 3 of 3
      • Gently push the RAM chip holder to the sides.
      Ask FixBot
    3. Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: step 7, image 1 of 3 Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: step 7, image 2 of 3 Asus Vivobook Q301LA-BHI5T02 RAM  Replacement: step 7, image 3 of 3
      • Remove the RAM from the device.
      Ask FixBot
Jorge Villarreal
397 Reputation
3 Guides authored
USF Tampa, Team S10-G3, Thompson Fall 2017 Member of USF Tampa, Team S10-G3, Thompson Fall 2017
USFT-THOMPSON-F17S10G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 36
All Time: 1,096
