Asus VivoTab Smart Speaker Replacement
    1. Asus VivoTab Smart Speaker Replacement, Speaker: step 1, image 1 of 3 Asus VivoTab Smart Speaker Replacement, Speaker: step 1, image 2 of 3 Asus VivoTab Smart Speaker Replacement, Speaker: step 1, image 3 of 3
      • Power off the device before you begin disassembly.
      • Place the device face down on a flat surface.
      • Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
      Ask FixBot
    2. Asus VivoTab Smart Speaker Replacement: step 2, image 1 of 3 Asus VivoTab Smart Speaker Replacement: step 2, image 2 of 3 Asus VivoTab Smart Speaker Replacement: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Take care not to break the speaker wire when unplugging it from the device.
      • Carefully unplug the speaker wire from the device by grabbing the wire near the white plug with tweezers and pulling gently.
      Ask FixBot
    3. Asus VivoTab Smart Speaker Replacement: step 3, image 1 of 2 Asus VivoTab Smart Speaker Replacement: step 3, image 2 of 2
      • Remove two 2.7 mm Phillips #00 screws.
      • Remove two 3.7 mm Phillips #00 screws.
      Ask FixBot
    4. Asus VivoTab Smart Speaker Replacement: step 4, image 1 of 1
      • Remove the speaker from the device by lifting up on it.
      Ask FixBot
Zach Hatten
563 Reputation
4 Guides authored
USF Tampa, Team 2-4, Sullivan Fall 2016 Member of USF Tampa, Team 2-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G4
4 Members
20 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 58
All Time: 775
