Asus VivoTab Smart Digitizer Touch Screen Replacement
Views: 6.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
121
All Time:
6,288
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to take apart your device and replace its Digitizer Touch Screen.
Be cautious not to smudge or scratch the screen during replacement.
Parts
Tools
    1. Asus VivoTab Smart Digitizer Touch Screen Replacement, Digitizer touch screen: step 1, image 1 of 3 Asus VivoTab Smart Digitizer Touch Screen Replacement, Digitizer touch screen: step 1, image 2 of 3 Asus VivoTab Smart Digitizer Touch Screen Replacement, Digitizer touch screen: step 1, image 3 of 3
      • Power off the device before you begin disassembly.
      • Place the device face down on a flat surface.
      • Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
      Ask FixBot
    2. Asus VivoTab Smart Digitizer Touch Screen Replacement: step 2, image 1 of 3 Asus VivoTab Smart Digitizer Touch Screen Replacement: step 2, image 2 of 3 Asus VivoTab Smart Digitizer Touch Screen Replacement: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Remove thirteen 3.7 mm Phillips #00 screws
      • Unplug the middle, red-tipped ribbon from the device by lifting up on it. This can be done with your hands or with tweezers.
      • The ribbons are fragile. Take care not to damage the ribbon while removing it.
      Ask FixBot
    3. Asus VivoTab Smart Digitizer Touch Screen Replacement: step 3, image 1 of 3 Asus VivoTab Smart Digitizer Touch Screen Replacement: step 3, image 2 of 3 Asus VivoTab Smart Digitizer Touch Screen Replacement: step 3, image 3 of 3
      • Unplug the camera ribbon by pulling out on it with a pair of tweezers.
      • Unplug the double ribbon from the device by pulling out on it with a pair of tweezers.
      • The ribbons are fragile. Take care not to tear or damage the ribbons when removing them from the device.
      Ask FixBot
    4. Asus VivoTab Smart Digitizer Touch Screen Replacement: step 4, image 1 of 3 Asus VivoTab Smart Digitizer Touch Screen Replacement: step 4, image 2 of 3 Asus VivoTab Smart Digitizer Touch Screen Replacement: step 4, image 3 of 3
      • Carefully lift the internal base of the device from the screen, also threading the ribbons through the slots.
      • Be sure to remove the tape above the right ribbon (not shown here) and pull it through the frame like the one in the middle. Not removing the tape can cause the ribbon to tear, possibly destroying the charging board.
      • The ribbons are fragile. Take care not to damage the ribbons when removing the base of the device.
      Ask FixBot
    5. Asus VivoTab Smart Digitizer Touch Screen Replacement: step 5, image 1 of 2 Asus VivoTab Smart Digitizer Touch Screen Replacement: step 5, image 2 of 2
      • Remove four 2.7 mm Phillips #00 screws.
      Ask FixBot
    6. Asus VivoTab Smart Digitizer Touch Screen Replacement: step 6, image 1 of 3 Asus VivoTab Smart Digitizer Touch Screen Replacement: step 6, image 2 of 3 Asus VivoTab Smart Digitizer Touch Screen Replacement: step 6, image 3 of 3
      • Carefully use tweezers to lift the LCD screen from the digitizer touch screen.
      • Use caution when touching the LCD screen with your hands. It may leave unwanted residue and finger prints.
      Ask FixBot
3 other people completed this guide.
Zach Hatten
563 Reputation
4 Guides authored
USF Tampa, Team 2-4, Sullivan Fall 2016 Member of USF Tampa, Team 2-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G4
4 Members
60 Guides authored
2 Guide Comments
Attention: this procedure has a big trap, in which I fell by following it: I have broken the glued connection between USB/power plug-in unit (on the right-side bottom) and its strip cable (visible on the right side and going into a whole on the right side bottom). Result: when I finished the assembly and tried to start the tablet, I only get the 3 blinking of the power LED, saying the the power connection is not OK.
The instructions should mention, that we have to disconnect also the power/USB strip-cable and take it out the whole, without braking the glued connection !!! - So, the photo in Etape 5 should show also the strip-cable still connected to the USB/power plug-in unit (green element on right-side bottom) !! - This in not the case on your Etape 5 photo and I am wondering how you could re-establish this connection when re-assembling the board.
Consequence: I have to find and buy a new power/USB connector (called DC board) which has the strip-cable included, i.e. attached.
Really annoying !
Richard - Reply Share
I don’t like this tutorial.
First: as Richard mentioned be very careful to get the flex out of the USB/power plug-in-unit. I broke it as well. It’s a newby thing. Doesn’t matter, it is easy to buy a new one but it takes time off course.
Second: This tutorial has the title of replacing the ** digitizer** but suggests to buy an LCD . Likely many people don’t need to buy a new LCD but a only a reliable digitizer (that’s the frame basically).
Third: Be very cautious about buying a new digitizer. Maybe for a reason it is not part of this tutorial. So you want to replace the digitizer, but there is not a digitizer sold as a part in this tuturial?! Weird. Anyway: I read there were THREE variations of this digitizer, and you really have to buy the one that fits your tablet. Others won’t work. So I suggest to read the flex. I have done this step, and now bought a new, original, digitizer for this tablet. But according a pro it still isn’t a safe buy. I don’t know if he is right, he might be though.
JustBe - Reply Share
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 121
All Time: 6,288
