Asus VivoTab Smart Battery Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
33
Past 30 Days:
111
All Time:
4,188
Comments: 2
2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show you how to remove the back panel and remove/replace the battery for the Asus VivoTab Smart tablet.
Once you are done, calibrate your newly installed battery by draining it below 10% and then charging it uninterrupted to 100%.
Parts
Tools
    1. Asus VivoTab Smart Battery Replacement, Battery: step 1, image 1 of 3 Asus VivoTab Smart Battery Replacement, Battery: step 1, image 2 of 3 Asus VivoTab Smart Battery Replacement, Battery: step 1, image 3 of 3
      • Power off the device before you begin disassembly.
      • Place the device face down on a flat surface.
      • Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
      Ask FixBot
    2. Asus VivoTab Smart Battery Replacement: step 2, image 1 of 3 Asus VivoTab Smart Battery Replacement: step 2, image 2 of 3 Asus VivoTab Smart Battery Replacement: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the tape covering the 3 ribbons by peeling it off with your hands or with the tweezers.
      • Carefully detach the ribbons from the device's motherboard by pulling outward using tweezers.
      Ask FixBot
    3. Asus VivoTab Smart Battery Replacement: step 3, image 1 of 3 Asus VivoTab Smart Battery Replacement: step 3, image 2 of 3 Asus VivoTab Smart Battery Replacement: step 3, image 3 of 3
      • The Philips #00 Screwdriver listed in the recommended tools will fit all the screws.
      • Remove the tape covering the areas marked by the black arrows
      • Remove two 3.7 mm Phillips #00 screws
      • Remove eleven 2.7 mm Phillips #00 screws
      Ask FixBot
    4. Asus VivoTab Smart Battery Replacement: step 4, image 1 of 2 Asus VivoTab Smart Battery Replacement: step 4, image 2 of 2
      • Be careful not to damage the speaker wire.
      • Gently unplug the speaker from the motherboard by grabbing the wire near the plastic white plug with tweezers and gently pulling.
      • Lift up on the speaker with your fingers to remove it.
      Ask FixBot
    5. Asus VivoTab Smart Battery Replacement: step 5, image 1 of 1
      • Gently lift the battery pressure plate off of the motherboard.
      Ask FixBot
    6. Asus VivoTab Smart Battery Replacement: step 6, image 1 of 2 Asus VivoTab Smart Battery Replacement: step 6, image 2 of 2
      • Use tweezers to separate the battery tray from the device
      • Lift the battery tray from the device using your hands.
      Ask FixBot
    7. Asus VivoTab Smart Battery Replacement: step 7, image 1 of 1
      • The battery is secured to the tray by a strong adhesive. Take care not to bend the tray when removing the battery.
      • Detach the battery from the tray by pulling the battery up from the tray with your hands.
      • If it is very difficult to lift the battery from the tray, you can use a blow dryer to heat the back side of the tray. This will weaken the adhesive and make it easier to remove.
      Ask FixBot
4 other people completed this guide.
Zach Hatten
563 Reputation
4 Guides authored
USF Tampa, Team 2-4, Sullivan Fall 2016 Member of USF Tampa, Team 2-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G4
4 Members
60 Guides authored
2 Guide Comments
Hi
So where is the next step ?!
Albert einstein - Reply Share
Hi
Please answer to me. This is so
Past 24 Hours: 3
Past 7 Days: 33
Past 30 Days: 111
All Time: 4,188
