Asus VivoTab Note 8 DC Board Replacement
  1. Asus VivoTab Note 8 DC Board Replacement, Back Panel: step 1, image 1 of 1
    • Remove the pen and memory card if you have them; they may get in the way when you are opening the device.
    • Pry open the edges of the cover using the plastic opening tool. The memory card slot is very useful for getting started.
    Ask FixBot
  2. Asus VivoTab Note 8 DC Board Replacement: step 2, image 1 of 2 Asus VivoTab Note 8 DC Board Replacement: step 2, image 2 of 2
    • Move the opening tool along the edges of the tablet and push up wherever you can. You may need to open up all of the sides to take the panel off.
    • Pull apart the sides of the casing by hand.
    Ask FixBot
  3. Asus VivoTab Note 8 DC Board Replacement: step 3, image 1 of 1
    • After pulling the panel off, put it to the side.
    Ask FixBot
  4. Asus VivoTab Note 8 DC Board Replacement, Motherboard: step 4, image 1 of 1
    • Unplug the battery from the motherboard.
    • Lodge something (a fingernail works fine) under the connecting piece and apply a force straight up and perpendicular to the back of the device.
    Ask FixBot
  5. Asus VivoTab Note 8 DC Board Replacement: step 5, image 1 of 1
    • Remove the screws from the black plastic restraint restricting the motherboard's movement using a Phillips #000 screwdriver.
    • Gently remove the black plastic restraint from the motherboard.
    Ask FixBot
  6. Asus VivoTab Note 8 DC Board Replacement: step 6, image 1 of 1
    • Remove the six screws holding the motherboard in place using a Phillips #000 screwdriver.
    Ask FixBot
  7. Asus VivoTab Note 8 DC Board Replacement: step 7, image 1 of 1
    • Gently pull out the remaining ribbons and cords still plugged into the motherboard.
    • Remove the motherboard from the device.
    Ask FixBot
  8. Asus VivoTab Note 8 DC Board Replacement, DC Board: step 8, image 1 of 2 Asus VivoTab Note 8 DC Board Replacement, DC Board: step 8, image 2 of 2
    • Remove the two Phillips #000 screws holding the board down.
    Ask FixBot
  9. Asus VivoTab Note 8 DC Board Replacement: step 9, image 1 of 1
    • Pull the board up using the opening tool.
    Ask FixBot
  10. Asus VivoTab Note 8 DC Board Replacement: step 10, image 1 of 2 Asus VivoTab Note 8 DC Board Replacement: step 10, image 2 of 2
    • Pull the DC board away while holding the ribbon cable.
    Ask FixBot
Ryan Spencer
756 Reputation
6 Guides authored
1 Guide Comment
Do you know where to buy the board online? I can't seem to find it anywhere
Chuo - Reply Share
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 35
All Time: 1,392
