Up to 20% off select tools
Asus VivoTab Note 8 Back Panel Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
74
All Time:
1,160
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 2 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Opening the back panel of the Asus VivoTab Note 8 is easy; however it is recommended to have a plastic opening tool to pry it off.
    1. Asus VivoTab Note 8 Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Remove the pen and memory card if you have them; they may get in the way when you are opening the device.
      • Pry open the edges of the cover using the plastic opening tool. The memory card slot is very useful for getting started.
      Ask FixBot
    2. Asus VivoTab Note 8 Back Panel Replacement: step 2, image 1 of 2 Asus VivoTab Note 8 Back Panel Replacement: step 2, image 2 of 2
      • Move the opening tool along the edges of the tablet and push up wherever you can. You may need to open up all of the sides to take the panel off.
      • Pull apart the sides of the casing by hand.
      Ask FixBot
    3. Asus VivoTab Note 8 Back Panel Replacement: step 3, image 1 of 1
      • After pulling the panel off, put it to the side.
      Ask FixBot
Author
with
Ryan Spencer
756 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 74
All Time: 1,160
