Asus VivoBook S200E-RHI3T73 Battery Replacement
    1. Asus VivoBook S200E-RHI3T73 Battery Replacement, Battery: step 1, image 1 of 1
      • Use a metal spudger to pry the bottom panel open.
      • Be gentle around the edges.
      • Lift the back panel to expose the inside of the laptop.
      Ask FixBot
    2. Asus VivoBook S200E-RHI3T73 Battery Replacement: step 2, image 1 of 2 Asus VivoBook S200E-RHI3T73 Battery Replacement: step 2, image 2 of 2
      • Using the same Phillips #0 screwdriver, remove the eight black 50mm screws surrounding the battery.
      Ask FixBot
    3. Asus VivoBook S200E-RHI3T73 Battery Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Using a set of precision tweezers, lift the motherboard connector tab.
      Ask FixBot
    4. Asus VivoBook S200E-RHI3T73 Battery Replacement: step 4, image 1 of 2 Asus VivoBook S200E-RHI3T73 Battery Replacement: step 4, image 2 of 2
      • Use a nylon spudger or your fingers to gently pry the battery up.
      • Remove the battery.
      • Metal spudgers can puncture an unprotected battery, potentially causing a fire.
      Ask FixBot
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 45
All Time: 3,507
