Asus VivoBook S14 SSD Replacement
    1. Asus VivoBook S14 SSD Replacement, Back Panel: step 1, image 1 of 2 Asus VivoBook S14 SSD Replacement, Back Panel: step 1, image 2 of 2
      • Remove all eleven 5 mm screws on the back panel with a Phillips #0 screwdriver.
      • Insert an iFixit opening tool between the back panel and the chassis. Carefully pry around the edges until the plastic clips release.
      • Do not force the cover. If you feel significant resistance, double-check for missed screws.
      • Lift the back panel off the laptop.
      Ask FixBot
    1. Asus VivoBook S14 SSD Replacement, SSD: step 2, image 1 of 1
      • The SSD card is in the middle of the motherboard below the fan.
      Ask FixBot
    2. Asus VivoBook S14 SSD Replacement: step 3, image 1 of 2 Asus VivoBook S14 SSD Replacement: step 3, image 2 of 2
      • Using a Phillips screwdriver to remove the single 2 mm screw securing the SSD card to the motherboard.
      Ask FixBot
    3. Asus VivoBook S14 SSD Replacement: step 4, image 1 of 1
      • Gently pull the SSD card out of its slot.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Alexis Harper
481 Reputation
4 Guides authored
UW Tacoma, Team E-3, Rose Winter 2026 Member of UW Tacoma, Team E-3, Rose Winter 2026
UWT-ROSE-W26SEG3
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 71
All Time: 220
