Asus VivoBook S14 Battery Replacement
    1. Asus VivoBook S14 Battery Replacement, Back Panel: step 1, image 1 of 2 Asus VivoBook S14 Battery Replacement, Back Panel: step 1, image 2 of 2
      • Remove all eleven 5 mm screws on the back panel with a Phillips #0 screwdriver.
      • Insert an iFixit opening tool between the back panel and the chassis. Carefully pry around the edges until the plastic clips release.
      • Do not force the cover. If you feel significant resistance, double-check for missed screws.
      • Lift the back panel off the laptop.
      Ask FixBot
    1. Asus VivoBook S14 Battery Replacement, Battery: step 2, image 1 of 1
      • Carefully detach the connector from the motherboard.
      • If the battery is swollen or is need of disposal, please follow this guide.
      Ask FixBot
    2. Asus VivoBook S14 Battery Replacement: step 3, image 1 of 2 Asus VivoBook S14 Battery Replacement: step 3, image 2 of 2
      • Remove the 5 mm screws holding the battery in place with a JIS #000 screwdriver.
      Ask FixBot
    3. Asus VivoBook S14 Battery Replacement: step 4, image 1 of 2 Asus VivoBook S14 Battery Replacement: step 4, image 2 of 2
      • Lift the battery out of the battery socket.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
1 Guide Comment
Hi where is bios battery?in Vivo book s14
Amir Du - Reply Share
Past 24 Hours: 8
Past 7 Days: 37
Past 30 Days: 144
All Time: 1,838
