Asus V6800V Wireless Card Replacement
    1. Asus V6800V Wireless Card Replacement, Battery: step 1, image 1 of 2 Asus V6800V Wireless Card Replacement, Battery: step 1, image 2 of 2
      • Place the computer upside down.
      • Using your thumbs, slide both latches away from each other (towards the outside).
      • Push the battery out with your fingers.
      • The actual battery is not pictured.
      Ask FixBot
    1. Asus V6800V Wireless Card Replacement, Wireless Card: step 2, image 1 of 2 Asus V6800V Wireless Card Replacement, Wireless Card: step 2, image 2 of 2
      • Remove the six screws highlighted on the picture.
      • Once the screws are removed, pry open the panel with the pry tool.
      • It should now look like this.
      Ask FixBot
    2. Asus V6800V Wireless Card Replacement: step 3, image 1 of 2 Asus V6800V Wireless Card Replacement: step 3, image 2 of 2
      • After removing that panel, locate the screw on the right as highlighted.
      • Remove that screw.
      • Pry open the side panel with the small prying tool as shown.
      • That panel should pop off and the wireless card will now be easily visible.
      Ask FixBot
    3. Asus V6800V Wireless Card Replacement: step 4, image 1 of 1
      • Place the small prying tool underneath the gold connector and gently apply pressure straight up until it pops off.
      • Repeat for the other one.
      • Place the gold connectors aside.
      Ask FixBot
    4. Asus V6800V Wireless Card Replacement: step 5, image 1 of 3 Asus V6800V Wireless Card Replacement: step 5, image 2 of 3 Asus V6800V Wireless Card Replacement: step 5, image 3 of 3
      • Locate the tabs that are holding the wireless card in place. These are highlighted in picture.
      • Place one finger on each tab and press each to the side away from the wireless card as shown.
      • The wireless card should pop up as shown. Pull up more with fingers to get more clearance.
      Ask FixBot
    5. Asus V6800V Wireless Card Replacement: step 6, image 1 of 2 Asus V6800V Wireless Card Replacement: step 6, image 2 of 2
      • To remove the wireless card, pull the card directly out.
      • It should come out with just a little bit of pressure.
      • It should look as shown when removed.
      Ask FixBot
Steven
32 Reputation
2 Guides authored
Cal Poly, Team 2-9, Johann Summer 2010 Member of Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 12
Past 30 Days: 25
All Time: 4,343
