Asus V6800V Lower Case Replacement
    1. Asus V6800V Lower Case Replacement, Battery: step 1, image 1 of 2 Asus V6800V Lower Case Replacement, Battery: step 1, image 2 of 2
      • Place the computer upside down.
      • Using your thumbs, slide both latches away from each other (towards the outside).
      • Push the battery out with your fingers.
      • The actual battery is not pictured.
      Ask FixBot
    1. Asus V6800V Lower Case Replacement, Keyboard: step 2, image 1 of 1
      • Using a Phillips #0 screwdriver, remove the two screws from the case.
      • These screws should have a "K" symbol next to them.
      Ask FixBot
    2. Asus V6800V Lower Case Replacement: step 3, image 1 of 3 Asus V6800V Lower Case Replacement: step 3, image 2 of 3 Asus V6800V Lower Case Replacement: step 3, image 3 of 3
      • Locate the four tabs above the F1, F10, INSERT, and between the F5 and F6 keys.
      • Starting with the tab above the F1 key, press the tabs inward using your fingernail or spudger. Continue this process for the rest of the tabs.
      • Once all four tabs have been released, the top half of the keyboard should be free.
      Ask FixBot
    3. Asus V6800V Lower Case Replacement: step 4, image 1 of 2 Asus V6800V Lower Case Replacement: step 4, image 2 of 2
      • Pull the keyboard up from the top at a 45 degree angle. Place it upside down on the touchpad.
      • Pull the wide ribbon cable laterally from its socket on the motherboard to free the keyboard.
      Ask FixBot
    1. Asus V6800V Lower Case Replacement, Lower Case: step 5, image 1 of 1
      • Using a Phillips #0 screwdriver, remove the screws at the bottom of the chassis to remove the top panel.
      • This will allow the lower case to be removed from the rest of the computer.
      Ask FixBot
    2. Asus V6800V Lower Case Replacement: step 6, image 1 of 1
      • Remove the six screws from below the keyboard with a Phillips #0 screwdriver.
      Ask FixBot
    3. Asus V6800V Lower Case Replacement: step 7, image 1 of 2 Asus V6800V Lower Case Replacement: step 7, image 2 of 2
      • Use your fingernails or a pry tool to gently separate both halves of the case. Begin at the front and work around the entire case.
      • Be cautious not to damage the cables that connect both sides of the case.
      Ask FixBot
    4. Asus V6800V Lower Case Replacement: step 8, image 1 of 3 Asus V6800V Lower Case Replacement: step 8, image 2 of 3 Asus V6800V Lower Case Replacement: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the internal cables from front to back.
      • Use your fingers to gently remove the cables from their sockets.
      • The cables that connect the display to the main chassis are difficult to pull out using your fingers. A tool, such as tweezers, may be needed.
      Ask FixBot
    5. Asus V6800V Lower Case Replacement: step 9, image 1 of 1
      • After separating the top and bottom halves of the case, lay them flat on the work area.
      Ask FixBot
Brian Tubb
272 Reputation
2 Guides authored
Cal Poly, Team 2-9, Johann Summer 2010 Member of Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 31
Past 30 Days: 113
All Time: 8,323
