Up to 20% off select tools
Asus V6800V Keyboard Replacement
Views: 5.5K
View statistics:
Past 24 Hours:
Past 7 Days:
Past 30 Days:
13
All Time:
5,525
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
    1. Asus V6800V Keyboard Replacement, Battery: step 1, image 1 of 2 Asus V6800V Keyboard Replacement, Battery: step 1, image 2 of 2
      • Place the computer upside down.
      • Using your thumbs, slide both latches away from each other (towards the outside).
      • Push the battery out with your fingers.
      • The actual battery is not pictured.
      Ask FixBot
    1. Asus V6800V Keyboard Replacement, Keyboard: step 2, image 1 of 1
      • Using a Phillips #0 screwdriver, remove the two screws from the case.
      • These screws should have a "K" symbol next to them.
      Ask FixBot
    2. Asus V6800V Keyboard Replacement: step 3, image 1 of 3 Asus V6800V Keyboard Replacement: step 3, image 2 of 3 Asus V6800V Keyboard Replacement: step 3, image 3 of 3
      • Locate the four tabs above the F1, F10, INSERT, and between the F5 and F6 keys.
      • Starting with the tab above the F1 key, press the tabs inward using your fingernail or spudger. Continue this process for the rest of the tabs.
      • Once all four tabs have been released, the top half of the keyboard should be free.
      Ask FixBot
    3. Asus V6800V Keyboard Replacement: step 4, image 1 of 2 Asus V6800V Keyboard Replacement: step 4, image 2 of 2
      • Pull the keyboard up from the top at a 45 degree angle. Place it upside down on the touchpad.
      • Pull the wide ribbon cable laterally from its socket on the motherboard to free the keyboard.
      Ask FixBot
Author
with
Steven
32 Reputation
2 Guides authored
Cal Poly, Team 2-9, Johann Summer 2010 Member of Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 13
All Time: 5,525
