Asus V6800V Hard Drive Replacement
    1. Asus V6800V Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Asus V6800V Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
      • Remove the two screws circled red using a Phillips #0 screwdriver.
      Ask FixBot
    2. Asus V6800V Hard Drive Replacement: step 2, image 1 of 2 Asus V6800V Hard Drive Replacement: step 2, image 2 of 2
      • Pry open the case using an iFixit opening tool.
      • Actual hard drive is not shown in the second image.
      Ask FixBot
    3. Asus V6800V Hard Drive Replacement: step 3, image 1 of 2 Asus V6800V Hard Drive Replacement: step 3, image 2 of 2
      • The highlighted area is where your hard drive would be. Slide it out away from its slot and pull it gently to remove.
      • Second image shows what it should look like once you remove the hard drive.
      Ask FixBot
Jong Park
114 Reputation
5 Guides authored
Cal Poly, Team 2-9, Johann Summer 2010 Member of Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 104
All Time: 3,401
