Up to 20% off select tools
Asus V6800V Fan Replacement
Views: 5.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
92
All Time:
5,757
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Fan is a very essential part of a laptop which prevents it from overheating. Your Asus V6800V Fan needs to be changed when your laptop is running slow due to overheating or the fan is making a usual noisy sound or in some cases the fan stops immediately after starting. Before changing your Asus V6800V Fan use this page to confirm that the problem is actually in the fan but not any other parts.
The replacement guide will help you change your Asus V6800V Fan in the following simple steps. It won’t take more than 30 minutes.
    1. Asus V6800V Fan Replacement, Battery: step 1, image 1 of 2 Asus V6800V Fan Replacement, Battery: step 1, image 2 of 2
      • Place the computer upside down.
      • Using your thumbs, slide both latches away from each other (towards the outside).
      • Push the battery out with your fingers.
      • The actual battery is not pictured.
      Ask FixBot
    1. Asus V6800V Fan Replacement, Fan: step 2, image 1 of 2 Asus V6800V Fan Replacement, Fan: step 2, image 2 of 2
      • Use the Phillips #0 to remove the six screws on the back of the device.
      • Gently open the cover using the tab located by the highlighted box.
      Ask FixBot
    2. Asus V6800V Fan Replacement: step 3, image 1 of 2 Asus V6800V Fan Replacement: step 3, image 2 of 2
      • Unplug the wires by pulling straight up on the white connector and away from the computer.
      • Make sure not to pull on the wires (as shown in the second picture). The white connector should pop off with very little force.
      Ask FixBot
    3. Asus V6800V Fan Replacement: step 4, image 1 of 2 Asus V6800V Fan Replacement: step 4, image 2 of 2
      • Use a Phillips #0 to remove the three screws holding the fan in place.
      Ask FixBot
    4. Asus V6800V Fan Replacement: step 5, image 1 of 2 Asus V6800V Fan Replacement: step 5, image 2 of 2
      • Remove the fan from the device.
      • The fan should remove easily.
      Ask FixBot
    5. Asus V6800V Fan Replacement: step 6, image 1 of 2 Asus V6800V Fan Replacement: step 6, image 2 of 2
      • Use a cotton swab or compressed air to blow air from the inside, out to clear dust from the vent or heat sink.
      Ask FixBot
Author
with
Jong Park
114 Reputation
5 Guides authored
Cal Poly, Team 2-9, Johann Summer 2010 Member of Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 92
All Time: 5,757
