Introduction
In this guide, you will learn how to replace the WiFi Card found in the Asus V500CA-DB51T. This guide was made to help with replacing a broken or defective WiFi Card, and is an easy repair for any skill level.
Remove the following ten screws securing the lower case to the upper case:
The top left and right corners have .7 cm screws.
The two top-middle and four bottom are .4 cm screws.
The middle left and right are .8 cm screws.
Remove the screws using the Phillips #00 screwdriver.
Locate the section of the device that houses the WiFi Card.
This should be a white, square-shaped object located just above the left end of the battery.
