Asus V500CA-DB51T Battery Replacement
    1. Asus V500CA-DB51T Battery  Replacement, Battery: step 1, image 1 of 2 Asus V500CA-DB51T Battery  Replacement, Battery: step 1, image 2 of 2
      • The top left and right corners have .7 cm screws.
      • The two top-middle and four bottom are .4 cm screws.
      • The middle left and right are .8 cm screws.
      • Remove the screws using the Phillips #00 screwdriver.
      Ask FixBot
    2. Asus V500CA-DB51T Battery  Replacement: step 2, image 1 of 2 Asus V500CA-DB51T Battery  Replacement: step 2, image 2 of 2
      • Wedge your fingers between the upper case and the lower case.
      • Gently pull the lower case away from the upper case.
      Ask FixBot
    3. Asus V500CA-DB51T Battery  Replacement: step 3, image 1 of 1
      • Use the flat end of the blue plastic opening tool to lift the battery connector up out of its socket on the motherboard.
      Ask FixBot
    4. Asus V500CA-DB51T Battery  Replacement: step 4, image 1 of 2 Asus V500CA-DB51T Battery  Replacement: step 4, image 2 of 2
      • Remove the tri-point screws that secure the battery to the casing.
      • All screws securing the battery in place are .5 cm tri-point screws.
      Ask FixBot
    5. Asus V500CA-DB51T Battery  Replacement: step 5, image 1 of 3 Asus V500CA-DB51T Battery  Replacement: step 5, image 2 of 3 Asus V500CA-DB51T Battery  Replacement: step 5, image 3 of 3
      • Use the opening tool to pop up the battery away from the casing.
      Ask FixBot
Galen P Garofalo
670 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 106
All Time: 1,008
