Up to 20% off select tools
Asus UL80VT Battery Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
50
All Time:
650
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 seconds - 1 minute
Difficulty: Easy
Introduction
Go to step 1 ↓
Replacing the battery is very straightforward. Once the battery is unlocked, it will come right out. This replacement can be done when battery life is poor or if the battery is not holding a charge at all.
    1. Asus UL80VT Battery  Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop so you can see the back side.
      Ask FixBot
    2. Asus UL80VT Battery  Replacement: step 2, image 1 of 2 Asus UL80VT Battery  Replacement: step 2, image 2 of 2
      • Identify the two slide locks below the battery. Slide them outward towards the unlock symbol. You should see a red mark that indicates that the battery is unlocked and is ready for removal.
      Ask FixBot
    3. Asus UL80VT Battery  Replacement: step 3, image 1 of 1
      • Now you can remove the battery while continuing to hold the right battery lock in the unlock position.
      Ask FixBot
Author
with
James DellaMorte
660 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 50
All Time: 650
