Up to 20% off select tools
Asus UL80J Keyboard Replacement
Views: 1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
77
All Time:
1,029
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
The keyboard is the device used to input data, text, and commands through to your laptop. If the keyboard is not responding or inputs incorrectly, you may have to replace your keyboard. This guide will show you how to replace the keyboard.
    1. Asus UL80J Keyboard Replacement, Battery: step 1, image 1 of 1
      • Place laptop face down with battery facing up.
      Ask FixBot
    2. Asus UL80J Keyboard Replacement: step 2, image 1 of 1
      • Slide unlock button to the right.
      Ask FixBot
    3. Asus UL80J Keyboard Replacement: step 3, image 1 of 3 Asus UL80J Keyboard Replacement: step 3, image 2 of 3 Asus UL80J Keyboard Replacement: step 3, image 3 of 3
      • Slide the button marked with an arrow to the left. The battery should now unclick. Slide the battery away from the laptop to remove it.
      Ask FixBot
    1. Asus UL80J Keyboard Replacement, Keyboard: step 4, image 1 of 1
      • Insert a plastic opening tool or a flat-head screwdriver between the laptop body and the keyboard.
      Ask FixBot
    2. Asus UL80J Keyboard Replacement: step 5, image 1 of 1
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Gently pry the keyboard up. This will allow you to unclip the keyboard.
      • Use an old plastic card or a similar flat object to prevent the keyboard from clipping back in while carefully working along the keyboard perimeter.
      • Unclipping sounds are normal.
      Ask FixBot
      • Keep unclipping the keyboard along the perimeter. Once the keyboard is unclipped, be careful and do not take it out right away, as there is still a ribbon that connects the keyboard with the rest of the computer located on the bottom.
      Ask FixBot
    3. Asus UL80J Keyboard Replacement: step 7, image 1 of 1
      • Slowly lift the keyboard and use flash light if needed to locate the ribbon cable on the bottom. Lift the ZIF connector tab before pulling the ribbon cable out.
      • Remove the tape from the ribbon cable if needed and remove the keyboard.
      Ask FixBot
Author
with
Kateryna Turchenko
201 Reputation
2 Guides authored
USF Tampa, Team S2-G4, Lacy Spring 2017 Member of USF Tampa, Team S2-G4, Lacy Spring 2017
USFT-LACY-S17S2G4
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 77
All Time: 1,029
