Asus U56E-BBL6 Optical Drive Replacement
    1. Asus U56E-BBL6 Optical Drive Replacement, Battery: step 1, image 1 of 1
      • Make sure you unplugged the laptop before you begin the replacement process.
      • Locate the battery locking tabs on the upper right and left corner.
      • Press the tabs in towards each other.
      Ask FixBot
    2. Asus U56E-BBL6 Optical Drive Replacement: step 2, image 1 of 1
      • Pull the battery outwards to remove it.
      Ask FixBot
    1. Asus U56E-BBL6 Optical Drive Replacement, Back Panel: step 3, image 1 of 2 Asus U56E-BBL6 Optical Drive Replacement, Back Panel: step 3, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the screws.
      Ask FixBot
    2. Asus U56E-BBL6 Optical Drive Replacement: step 4, image 1 of 1
      • Lift backplate and remove from the case.
      Ask FixBot
    1. Asus U56E-BBL6 Optical Drive Replacement, RAM: step 5, image 1 of 1
      • Once inside the panel, locate your RAM sticks.
      Ask FixBot
    2. Asus U56E-BBL6 Optical Drive Replacement: step 6, image 1 of 2 Asus U56E-BBL6 Optical Drive Replacement: step 6, image 2 of 2
      • This device is embedded with two RAM sticks.
      • Push the metal brackets carefully to release and remove the RAM stick .
      Ask FixBot
    3. Asus U56E-BBL6 Optical Drive Replacement: step 7, image 1 of 2 Asus U56E-BBL6 Optical Drive Replacement: step 7, image 2 of 2
      • Repeat the previous step for removing the other RAM stick.
      Ask FixBot
    1. Asus U56E-BBL6 Optical Drive Replacement, Keyboard: step 8, image 1 of 1
      • Using a Phillips #00, remove the four screws.
      Ask FixBot
    2. Asus U56E-BBL6 Optical Drive Replacement: step 9, image 1 of 2 Asus U56E-BBL6 Optical Drive Replacement: step 9, image 2 of 2
      Ask FixBot
    3. Asus U56E-BBL6 Optical Drive Replacement: step 10, image 1 of 1
      • Use a plastic opening tool around the entire edge.
      • Separate the case from the keyboard.
      Ask FixBot
    4. Asus U56E-BBL6 Optical Drive Replacement: step 11, image 1 of 1
      • Ensure the laptop is face up for this step.
      • Gently lift the keyboard from the base of the laptop.
      • Be careful of the ribbon cables connecting the keyboard.
      Ask FixBot
    5. Asus U56E-BBL6 Optical Drive Replacement: step 12, image 1 of 1
      • Gently tug the ribbon cables free from their slots.
      Ask FixBot
    6. Asus U56E-BBL6 Optical Drive Replacement: step 13, image 1 of 2 Asus U56E-BBL6 Optical Drive Replacement: step 13, image 2 of 2
      • Using both hands, pull the keyboard back and out, fully separating the keyboard from the laptop.
      Ask FixBot
    1. Asus U56E-BBL6 Optical Drive Replacement, Optical Drive: step 14, image 1 of 1
      • Using a plastic opening tool, separate the optical drive from the laptop frame.
      • Be careful to leverage the plastic opening tool against the frame and not the motherboard as this may cause damage.
      Ask FixBot
    2. Asus U56E-BBL6 Optical Drive Replacement: step 15, image 1 of 1
      • Remove the optical drive by sliding it out from the case.
      Ask FixBot
Josiah Allard
733 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 17
All Time: 400
