Asus U56E Laptop Screen Replacement
    1. Asus U56E Laptop Screen Replacement, Screen: step 1, image 1 of 2 Asus U56E Laptop Screen Replacement, Screen: step 1, image 2 of 2
      • Position the laptop on a flat, stable surface, with the underside facing upward.
      Ask FixBot
    2. Asus U56E Laptop Screen Replacement: step 2, image 1 of 3 Asus U56E Laptop Screen Replacement: step 2, image 2 of 3 Asus U56E Laptop Screen Replacement: step 2, image 3 of 3
      • Make sure the laptop is unplugged before removing the battery to avoid risk of electric shock.
      • Slide the two battery lock switches toward each other.
      • Lift the battery to remove it from the laptop.
      Ask FixBot
    3. Asus U56E Laptop Screen Replacement: step 3, image 1 of 3 Asus U56E Laptop Screen Replacement: step 3, image 2 of 3 Asus U56E Laptop Screen Replacement: step 3, image 3 of 3
      • Remove the 3 Phillips #00 screws holding on the back cover of the laptop.
      • Lift the cover, exposing the laptop hard drive and RAM.
      Ask FixBot
    4. Asus U56E Laptop Screen Replacement: step 4, image 1 of 2 Asus U56E Laptop Screen Replacement: step 4, image 2 of 2
      • Remove the eight small screws holding the hard drive in.
      • The hard drive cover can now be removed by lifting the tab on the left.
      Ask FixBot
    5. Asus U56E Laptop Screen Replacement: step 5, image 1 of 1
      • Gently slide the hard drive left toward the edge of the laptop, then lift up to remove it.
      Ask FixBot
    6. Asus U56E Laptop Screen Replacement: step 6, image 1 of 2 Asus U56E Laptop Screen Replacement: step 6, image 2 of 2
      • Remove the 4 Phillips #00 screws around the RAM.
      Ask FixBot
    7. Asus U56E Laptop Screen Replacement: step 7, image 1 of 2 Asus U56E Laptop Screen Replacement: step 7, image 2 of 2
      • Remove the 10 Phillips #00 screws from the bottom of the laptop.
      • Remove 10 Phillips #000 screws from under the battery.
      Ask FixBot
    8. Asus U56E Laptop Screen Replacement: step 8, image 1 of 2 Asus U56E Laptop Screen Replacement: step 8, image 2 of 2
      • Slide the optical drive out of the laptop.
      • Gently lift the rear plastic hinge cover to separate it from the laptop.
      Ask FixBot
    9. Asus U56E Laptop Screen Replacement: step 9, image 1 of 3 Asus U56E Laptop Screen Replacement: step 9, image 2 of 3 Asus U56E Laptop Screen Replacement: step 9, image 3 of 3
      • Remove the 3 Phillips #000 screws from each side of the hinge (six screws in total).
      • Gently lift the thin plastic cover from each side, exposing the laptop hinge.
      • Be aware of the thin cables still connected to the screen.
      Ask FixBot
    10. Asus U56E Laptop Screen Replacement: step 10, image 1 of 2 Asus U56E Laptop Screen Replacement: step 10, image 2 of 2
      • Gently lift around the perimeter of keyboard to separate it from the laptop body.
      • It may help to use a Plastic Opening Tool.
      • Be careful not to pull too hard on the keyboard - It's connected to the motherboard with a thin ribbon cable!
      Ask FixBot
    11. Asus U56E Laptop Screen Replacement: step 11, image 1 of 3 Asus U56E Laptop Screen Replacement: step 11, image 2 of 3 Asus U56E Laptop Screen Replacement: step 11, image 3 of 3
      • Pull the display connector straight up to remove it from the motherboard.
      • Carefully detach the white and black WiFi antennas from the wireless adapter.
      Ask FixBot
    12. Asus U56E Laptop Screen Replacement: step 12, image 1 of 1
      • The screen can now be safely removed from the laptop.
      Ask FixBot
David Zilar
167 Reputation
1 Guide authored
Cal Poly, Team 14-5, Green Fall 2015 Member of Cal Poly, Team 14-5, Green Fall 2015
CPSU-GREEN-F15S14G5
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 114
All Time: 1,977
