Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓We are going to teach you how to remove/replace the Upper Case of your Asus U50F-RBBAG05.
Tools
Spudger4.9
Turn the laptop over so the bottom is facing up.
Slide the two tabs on the bottom of the laptop toward the edges of laptop.
Slide the left tab to the left to lock it into the unlocked position. The red showing next to the tab signifies that it's unlocked.
Push back on the silver clips shown in the picture until you hear/feel a pop.
Use the Phillips #1 to remove two screws from the fan that attach it to the motherboard.
Remove the four screws on the heat sink.
Insert one of the pry tools under a top corner and the other tool under the side of the same corner. Make sure to get under the metal of the keyboard, not just the first layer of plastic. Then pry the corner down and out from under the little overhang its sitting under.
Next, slide the pry tool on the top over to the next overhang and insert the second tool on the other side. Push down and pry out the keyboard.
Repeat the same process all the way down to the opposite corner.
Remove the six screws from the outer lower case.
Remove the four screws from the hinges.
Remove the three screws on the inner lower case.
Remove the three screws from the optical drive area.
