Asus U50F-RBBAG05 Motherboard Replacement
    1. Asus U50F-RBBAG05  Motherboard Replacement, Battery: step 1, image 1 of 1
      • Turn the laptop over so the bottom is facing up.
      • Slide the two tabs on the bottom of the laptop toward the edges of laptop.
      • Slide the left tab to the left to lock it into the unlocked position. The red showing next to the tab signifies that it's unlocked.
      • You will have to hold the right tab to the right to keep the slot unlocked while removing the battery.
      Ask FixBot
    2. Asus U50F-RBBAG05  Motherboard Replacement: step 2, image 1 of 2 Asus U50F-RBBAG05  Motherboard Replacement: step 2, image 2 of 2
      • Hold down the tab on the right side, then begin sliding the battery out.
      • Remove the old battery.
      • Next, insert the new battery into the empty slot. Release the right tab to begin locking the new battery into place. Slide the left tab to the right to completely lock the battery into the slot. The red that was showing near the left tab should be gone. This signifies that the battery is locked into place.
      Ask FixBot
    1. Asus U50F-RBBAG05  Motherboard Replacement, Underpanel: step 3, image 1 of 1
      • Remove the six screws using a Phillips #1 screwdriver.
      Ask FixBot
    2. Asus U50F-RBBAG05  Motherboard Replacement: step 4, image 1 of 1
      • Pry the lower panel up with your fingernail or a spudger.
      Ask FixBot
    3. Asus U50F-RBBAG05  Motherboard Replacement: step 5, image 1 of 2 Asus U50F-RBBAG05  Motherboard Replacement: step 5, image 2 of 2
      • Lift up on the panel and remove it.
      Ask FixBot
    1. Asus U50F-RBBAG05  Motherboard Replacement, Random Access Memory (RAM): step 6, image 1 of 2 Asus U50F-RBBAG05  Motherboard Replacement, Random Access Memory (RAM): step 6, image 2 of 2
      • Push back on the silver clips shown in the picture until you hear/feel a pop.
      Ask FixBot
    2. Asus U50F-RBBAG05  Motherboard Replacement: step 7, image 1 of 2 Asus U50F-RBBAG05  Motherboard Replacement: step 7, image 2 of 2
      • Pull back on the RAM card and remove it.
      • Repeat for the lower RAM card.
      Ask FixBot
    1. Asus U50F-RBBAG05  Motherboard Replacement, Hard Drive: step 8, image 1 of 1
      • Remove the two screws using a Phillips #1 screwdriver.
      Ask FixBot
    2. Asus U50F-RBBAG05  Motherboard Replacement: step 9, image 1 of 2 Asus U50F-RBBAG05  Motherboard Replacement: step 9, image 2 of 2
      • Using your finger, push the hard drive back.
      • Pry up the drive with an opening tool (or your fingernail).
      Ask FixBot
    3. Asus U50F-RBBAG05  Motherboard Replacement: step 10, image 1 of 2 Asus U50F-RBBAG05  Motherboard Replacement: step 10, image 2 of 2
      • Pull back on the hard drive and lift upwards.
      • Remove the component completely.
      Ask FixBot
    1. Asus U50F-RBBAG05  Motherboard Replacement, Fan and Heat Sink: step 11, image 1 of 2 Asus U50F-RBBAG05  Motherboard Replacement, Fan and Heat Sink: step 11, image 2 of 2
      • Use the Phillips #1 to remove two screws from the fan that attach it to the motherboard.
      • Remove the four screws on the heat sink.
      Ask FixBot
    2. Asus U50F-RBBAG05  Motherboard Replacement: step 12, image 1 of 1
      • Pull the bundled cable away from the connector in the same direction the individual wires are running.
      • Potential for device damage: Pull evenly on the connector so that no individual wires are overly strained.
      Ask FixBot
    3. Asus U50F-RBBAG05  Motherboard Replacement: step 13, image 1 of 2 Asus U50F-RBBAG05  Motherboard Replacement: step 13, image 2 of 2
      • Pull up the heat sink a bit and then pull back.
      • There's an overhanging piece of the lower panel near the fan that you have to scoot out of.
      • Lift and remove both the fan and heat sink.
      Ask FixBot
    1. Asus U50F-RBBAG05  Motherboard Replacement, Optical Drive: step 14, image 1 of 1
      • Remove the single screw.
      Ask FixBot
    2. Asus U50F-RBBAG05  Motherboard Replacement: step 15, image 1 of 1
      • Use the plastic opening tool to push the drive out from the back.
      Ask FixBot
    3. Asus U50F-RBBAG05  Motherboard Replacement: step 16, image 1 of 2 Asus U50F-RBBAG05  Motherboard Replacement: step 16, image 2 of 2
      • Pull the drive out and remove completely.
      • When reassembling the drive, lay the laptop with the base towards the floor. Then, push the drive all the way in. Otherwise, the drive will become stuck and be difficult to reassemble.
      Ask FixBot
    1. Asus U50F-RBBAG05  Motherboard Replacement, Keyboard: step 17, image 1 of 3 Asus U50F-RBBAG05  Motherboard Replacement, Keyboard: step 17, image 2 of 3 Asus U50F-RBBAG05  Motherboard Replacement, Keyboard: step 17, image 3 of 3
      • Insert one of the pry tools under a top corner and the other tool under the side of the same corner. Make sure to get under the metal of the keyboard, not just the first layer of plastic. Then pry the corner down and out from under the little overhang its sitting under.
      • Next, slide the pry tool on the top over to the next overhang and insert the second tool on the other side. Push down and pry out the keyboard.
      • Repeat the same process all the way down to the opposite corner.
      Ask FixBot
    2. Asus U50F-RBBAG05  Motherboard Replacement: step 18, image 1 of 2 Asus U50F-RBBAG05  Motherboard Replacement: step 18, image 2 of 2
      • Once the keyboard is free, lift it up slightly and release the cable connection underneath.
      Ask FixBot
    3. Asus U50F-RBBAG05  Motherboard Replacement: step 19, image 1 of 2 Asus U50F-RBBAG05  Motherboard Replacement: step 19, image 2 of 2
      • Last, remove the keyboard completely from the computer.
      Ask FixBot
    1. Asus U50F-RBBAG05  Motherboard Replacement, Upper Case: step 20, image 1 of 3 Asus U50F-RBBAG05  Motherboard Replacement, Upper Case: step 20, image 2 of 3 Asus U50F-RBBAG05  Motherboard Replacement, Upper Case: step 20, image 3 of 3
      • Remove the six screws from the outer lower case.
      • Remove the four screws from the hinges.
      • Remove the three screws on the inner lower case.
      • Remove the three screws from the optical drive area.
      Ask FixBot
    2. Asus U50F-RBBAG05  Motherboard Replacement: step 21, image 1 of 2 Asus U50F-RBBAG05  Motherboard Replacement: step 21, image 2 of 2
      • Remove the two screws from the metal frame.
      Ask FixBot
    3. Asus U50F-RBBAG05  Motherboard Replacement: step 22, image 1 of 3 Asus U50F-RBBAG05  Motherboard Replacement: step 22, image 2 of 3 Asus U50F-RBBAG05  Motherboard Replacement: step 22, image 3 of 3
      • Pull the two bundled cables away from the connector in the same direction as the individual wires are running.
      • Potential for device damage: Pull evenly on the full width of the cable so that no individual wires are overly strained.
      • Pull the no-fuss ribbon cable straight out of the connector.
      • Potential for device damage: These kinds of connectors are fairly rare, so check carefully for a way to release the connector before you resort to pulling on the ribbon cable.
      • Pull the single bundled cable away from the connector in the same direction as the individual wires are running.
      Ask FixBot
    4. Asus U50F-RBBAG05  Motherboard Replacement: step 23, image 1 of 1
      • Lift up and remove the upper case.
      Ask FixBot
    1. Asus U50F-RBBAG05  Motherboard Replacement, Motherboard: step 24, image 1 of 2 Asus U50F-RBBAG05  Motherboard Replacement, Motherboard: step 24, image 2 of 2
      • Remove the six screws from the motherboard.
      Ask FixBot
    2. Asus U50F-RBBAG05  Motherboard Replacement: step 25, image 1 of 3 Asus U50F-RBBAG05  Motherboard Replacement: step 25, image 2 of 3 Asus U50F-RBBAG05  Motherboard Replacement: step 25, image 3 of 3
      • Pull three bundled cables away from their connectors in the same direction as the individual wires are running.
      • Potential for device damage: Pull evenly on the full width of each cable so that no individual wires are overly strained.
      Ask FixBot
    3. Asus U50F-RBBAG05  Motherboard Replacement: step 26, image 1 of 3 Asus U50F-RBBAG05  Motherboard Replacement: step 26, image 2 of 3 Asus U50F-RBBAG05  Motherboard Replacement: step 26, image 3 of 3
      • Flip the laptop over.
      • Disconnect one wire.
      • Remove the tape connected to the white wire (which should not be connected to anything, but disconnect it if it is) and disconnect the black wire.
      Ask FixBot
    4. Asus U50F-RBBAG05  Motherboard Replacement: step 27, image 1 of 1
      • Flip laptop back over and remove the motherboard completely.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 94
All Time: 1,172
