Asus Transformer T100 Rear Cover Replacement
    1. Asus Transformer T100 Rear Cover Replacement, Rear Cover: step 1, image 1 of 2 Asus Transformer T100 Rear Cover Replacement, Rear Cover: step 1, image 2 of 2
      • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
      • Remove the tablet by lifting up.
      Ask FixBot
    2. Asus Transformer T100 Rear Cover Replacement: step 2, image 1 of 2 Asus Transformer T100 Rear Cover Replacement: step 2, image 2 of 2
      • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
      • With a little force, you will feel the clips release.
      Ask FixBot
    3. Asus Transformer T100 Rear Cover Replacement: step 3, image 1 of 1
      • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
      • Do not break these clips; otherwise, the screen will become less secure.
      Ask FixBot
    4. Asus Transformer T100 Rear Cover Replacement: step 4, image 1 of 2 Asus Transformer T100 Rear Cover Replacement: step 4, image 2 of 2
      • Remove the rear casing.
      Ask FixBot
7 other people completed this guide.
Taylor Pantiga
1,629 Reputation
6 Guides authored
Cal Poly, Team 13-31, Maness Spring 2014 Member of Cal Poly, Team 13-31, Maness Spring 2014
CPSU-MANESS-S14S13G31
3 Members
72 Guides authored
5 Guide Comments
This is completely wrong. The outside case of the ASUS T100 is brushed metal.
darimini76 - Reply Share
there is also a white version, so actually not wrong
Jordi Vanwinkle - Reply Share
Was able to remove the back cover. Needed to unplug the battery and plug it back in so the the Notebook would boot. It now boots perfectly but
when we replace the back cover it snaps in at the sides and bottom but
WILL NOT Snap in on the top (where the power switch is). All tabs on the back cover and the frame are perfect and not broken but the back cover will not snap closed completely at the top. It still powers on but the power switch sticks and have to press near the switch so it releases in the back cover cavity at the top. Anyone have any ideas on this issue. Thanks
ldajnowski - Reply Share
I had the same problem. Answer is not to start assemble from the top. Instead, start from the side where there is the SD slot or from the bottom end. Then everything will go. Good luck.
Bac Nguyen Ninh - Reply Share
Take out your Micro Sd card first!! You will snap it in two!
Milk - Reply Share
Past 24 Hours: 3
Past 7 Days: 33
Past 30 Days: 115
All Time: 16,797
