Asus Transformer T100 Front Facing Camera Board Replacement
Views: 4.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
27
Past 30 Days:
100
All Time:
4,453
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Use this guide to replace the front-facing camera board on your Asus Transformer T100.
Tools
    1. Asus Transformer T100 Front Facing Camera Board Replacement, Rear Cover: step 1, image 1 of 2 Asus Transformer T100 Front Facing Camera Board Replacement, Rear Cover: step 1, image 2 of 2
      • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
      • Remove the tablet by lifting up.
      Ask FixBot
    2. Asus Transformer T100 Front Facing Camera Board Replacement: step 2, image 1 of 2 Asus Transformer T100 Front Facing Camera Board Replacement: step 2, image 2 of 2
      • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
      • With a little force, you will feel the clips release.
      Ask FixBot
    3. Asus Transformer T100 Front Facing Camera Board Replacement: step 3, image 1 of 1
      • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
      • Do not break these clips; otherwise, the screen will become less secure.
      Ask FixBot
    4. Asus Transformer T100 Front Facing Camera Board Replacement: step 4, image 1 of 2 Asus Transformer T100 Front Facing Camera Board Replacement: step 4, image 2 of 2
      • Remove the rear casing.
      Ask FixBot
    1. Asus Transformer T100 Front Facing Camera Board Replacement, Front Facing Camera Board: step 5, image 1 of 1
      • The camera board is located in the red square in this image.
      Ask FixBot
    2. Asus Transformer T100 Front Facing Camera Board Replacement: step 6, image 1 of 2 Asus Transformer T100 Front Facing Camera Board Replacement: step 6, image 2 of 2
      • Remove the two screws on the camera board using a Phillips #1 Screwdriver.
      Ask FixBot
    3. Asus Transformer T100 Front Facing Camera Board Replacement: step 7, image 1 of 3 Asus Transformer T100 Front Facing Camera Board Replacement: step 7, image 2 of 3 Asus Transformer T100 Front Facing Camera Board Replacement: step 7, image 3 of 3
      • Lift up the power button cable retention clip on the motherboard and pull the cable out.
      Ask FixBot
    4. Asus Transformer T100 Front Facing Camera Board Replacement: step 8, image 1 of 2 Asus Transformer T100 Front Facing Camera Board Replacement: step 8, image 2 of 2
      • On the camera connection apparatus, locate the silver tape that connects to the tablet.
      • Peel the silver tape off of the tablet on both sides of the connection apparatus.
      • If this step has been completed correctly, the camera board should be loose, with the tape still attached to the connection apparatus.
      Ask FixBot
    5. Asus Transformer T100 Front Facing Camera Board Replacement: step 9, image 1 of 3 Asus Transformer T100 Front Facing Camera Board Replacement: step 9, image 2 of 3 Asus Transformer T100 Front Facing Camera Board Replacement: step 9, image 3 of 3
      • Gently pull the Orange ribbon cable out of the connection port.
      • This port has no clip. The orange apparatus should slide out with a small tug.
      Ask FixBot
2 other people completed this guide.
Taylor Pantiga
1,629 Reputation
6 Guides authored
Cal Poly, Team 13-31, Maness Spring 2014 Member of Cal Poly, Team 13-31, Maness Spring 2014
CPSU-MANESS-S14S13G31
3 Members
72 Guides authored
1 Guide Comment
Hello, can you please tell a manufacturer of the camera (is it writter somethere on it)?
Alexius Hoopakele Ae - Reply Share
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 100
All Time: 4,453
