Up to 20% off select tools
Asus Transformer T100 Button Module Replacement
Views: 6.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
93
All Time:
6,911
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
  • Tweezers
  • iFixit Opening Tool
    4.8
  • Spudger
    4.9
Introduction
Go to step 1 ↓
All the buttons on the tablet are located in one corner. They are all controlled by a button module board, which can be removed if desired.
    1. Asus Transformer T100 Button Module Replacement, Rear Cover: step 1, image 1 of 2 Asus Transformer T100 Button Module Replacement, Rear Cover: step 1, image 2 of 2
      • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
      • Remove the tablet by lifting up.
      Ask FixBot
    2. Asus Transformer T100 Button Module Replacement: step 2, image 1 of 2 Asus Transformer T100 Button Module Replacement: step 2, image 2 of 2
      • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
      • With a little force, you will feel the clips release.
      Ask FixBot
    3. Asus Transformer T100 Button Module Replacement: step 3, image 1 of 1
      • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
      • Do not break these clips; otherwise, the screen will become less secure.
      Ask FixBot
    4. Asus Transformer T100 Button Module Replacement: step 4, image 1 of 2 Asus Transformer T100 Button Module Replacement: step 4, image 2 of 2
      • Remove the rear casing.
      Ask FixBot
    1. Asus Transformer T100 Button Module Replacement, Button Module: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Unclip the white connection clip using a pair of tweezers.
      Ask FixBot
    2. Asus Transformer T100 Button Module Replacement: step 6, image 1 of 2 Asus Transformer T100 Button Module Replacement: step 6, image 2 of 2
      • Pull the connection apparatus from the connection clip on the board using a pair of tweezers.
      Ask FixBot
    3. Asus Transformer T100 Button Module Replacement: step 7, image 1 of 1
      • Gently fold the connection apparatus back away from your work area.
      Ask FixBot
    4. Asus Transformer T100 Button Module Replacement: step 8, image 1 of 3 Asus Transformer T100 Button Module Replacement: step 8, image 2 of 3 Asus Transformer T100 Button Module Replacement: step 8, image 3 of 3
      • Remove the screws using a Phillips Head #1 screwdriver.
      • Remove the power button module.
      Ask FixBot
4 other people completed this guide.
Author
with
Taylor Pantiga
1,632 Reputation
6 Guides authored
Cal Poly, Team 13-31, Maness Spring 2014 Member of Cal Poly, Team 13-31, Maness Spring 2014
CPSU-MANESS-S14S13G31
3 Members
72 Guides authored
1 Guide Comment
My problem is that when reinstalltng the back cover the button does not fit the button module to press the on/off switch. The switch works allright.
What can i do? At this moment I can only switch the tablet on after removing the back cover.
Rudolf Guys - Reply Share
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 93
All Time: 6,911
