Asus Transformer Pad TF103C Speakers Replacement
    1. Asus Transformer Pad TF103C Speakers Replacement, Speakers: step 1, image 1 of 1
      • Shut down your tablet before beginning the repair.
      • Insert the plastic opening tool on the side of the tablet.
      • Gently pull upwards and carefully pry open the tablet.
      Ask FixBot
    2. Asus Transformer Pad TF103C Speakers Replacement: step 2, image 1 of 1
      • Slide the tool around all four sides of the tablet while gently pulling the tool up.
      Ask FixBot
    3. Asus Transformer Pad TF103C Speakers Replacement: step 3, image 1 of 1
      • Remove the back cover once you have loosened it from the tablet. Set the back cover aside.
      • Rotate the tablet to match the picture.
      Ask FixBot
    4. Asus Transformer Pad TF103C Speakers Replacement: step 4, image 1 of 1
      • Carefully unplug the rainbow cable from the motherboard.
      Ask FixBot
    5. Asus Transformer Pad TF103C Speakers Replacement: step 5, image 1 of 1
      • Use the plastic opening tool to carefully pry the battery out from the frame.
      Ask FixBot
    6. Asus Transformer Pad TF103C Speakers Replacement: step 6, image 1 of 2 Asus Transformer Pad TF103C Speakers Replacement: step 6, image 2 of 2
      • Use the JIS #000 screwdriver to remove the four screws.
      • Keep the screws together and organized. (Label the screws, if necessary).
      Ask FixBot
    7. Asus Transformer Pad TF103C Speakers Replacement: step 7, image 1 of 1
      • Take the ground wire out from the top of the TF103C-L (left) speaker.
      • If you pull on the wire too much it will break off.
      • If you break the wire off you can solder it back on.
      Ask FixBot
    8. Asus Transformer Pad TF103C Speakers Replacement: step 8, image 1 of 1
      • Remove the tape and unplug the wire that is connected to both of the speakers.
      Ask FixBot
    9. Asus Transformer Pad TF103C Speakers Replacement: step 9, image 1 of 2 Asus Transformer Pad TF103C Speakers Replacement: step 9, image 2 of 2
      • Remove the two speakers from the frame.
      Ask FixBot
Tyler Ellis
668 Reputation
4 Guides authored
UMass Dartmouth, Team 3-6, Shastany Fall 2015 Member of UMass Dartmouth, Team 3-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 28
Past 30 Days: 79
All Time: 858
