Asus Transformer Pad TF103C Battery Replacement
    1. Asus Transformer Pad TF103C Battery Replacement, Battery: step 1, image 1 of 1
      • Make sure the power is off.
      • Insert the plastic opening tool into a crack on side of the tablet.
      • You can use a thin screwdriver if you don't have the opening tool.
      • Carefully pull the tool upwards to and pry open the Transformer pad.
      • Make sure the SD card slot is empty first.
      Ask FixBot
    2. Asus Transformer Pad TF103C Battery Replacement: step 2, image 1 of 1
      • Slide the tool in the gap along all four sides, continually pulling the tool upwards.
      Ask FixBot
    3. Asus Transformer Pad TF103C Battery Replacement: step 3, image 1 of 1
      • Remove the back cover once it is loose and set it aside.
      • Rotate the tablet so it matches the picture.
      Ask FixBot
    4. Asus Transformer Pad TF103C Battery Replacement: step 4, image 1 of 1
      • Carefully unplug the battery cable from the motherboard by grabbing the wires close to the black piece and pulling it out of the housing.
      Ask FixBot
    5. Asus Transformer Pad TF103C Battery Replacement: step 5, image 1 of 2 Asus Transformer Pad TF103C Battery Replacement: step 5, image 2 of 2
      • Carefully pry the battery out of the tablet with the opening tool.
      • Replace battery with a new +3.7V=19Wh Li-polymer Battery Pack C11P1328.
      • There may be some tape on the battery, so you may hear pulling as you pry.
      Ask FixBot
5 other people completed this guide.
Kelsey Korin Sovik
188 Reputation
1 Guide authored
UMass Dartmouth, Team 3-6, Shastany Fall 2015 Member of UMass Dartmouth, Team 3-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G6
4 Members
60 Guides authored
5 Guide Comments
I had problems with the power button and thanks to your detailed explaination I managed to get the things ok
thanks a lot
Paolo
imperfezioni - Reply Share
My tab didn't turn on (stuck in booting limbo), didn't want to wait for a month or so till the battery dropped to 0%, so I tried this method instead. Done everything correctly. I'm sure I didn't screw up. Tablet won't start again (not even charging). I'm not sure if is either the faulty battery or the chipset attached to it. Either way, is a crappy tablet, never happened to lose a device so easily after a DIY repair. This would never happened if only Asus did insert reset buttons on their devices (or a soft reset button sequence). Will never buy an Asus tablet again.
Makurt - Reply Share
Did you plug the new battery wires correctly
red on red and so on the other?
Gerardcharles - Reply Share
Hi, i changed the battery, but now I have kind of a situation with this. My brand new battery is losing energy pretty fast , until 2%. When this reach 2% I can use the tablet for more than 10h with the screen on, or more. But if I use it for 2 h , in 2% , an then I close the screen for 5 minutes, the tablet shut down , and I can't open it until I put back the charger. Even though I have plenty of juice in the battery. How do I fix this ? Is there a way to recalibrate the software? I already tried to connect and disconnect the battery and charger back to 100. It doesn't work. I reinstalled the latest version of software. Doesn't work. Can anyone help me ?
Gica Leonte - Reply Share
I have an Asus Transformer pad. I bought it brand new 2 years ago. I charged the battery andturned it on. It turned on one time. I tried to turn it on a second time and couldn't do it. I sent it back to Asus for repair. They claimed they repaired it. I got it back and tried turning it on after charging battery. Again..went on but wouldn't ever come on again. This unit was obviously never checked out for qualify control. I never used it. Not even once! What a total ripoff! I will Never buy Asus again.
Izzorobert@yahoo.com
rizzostar - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 30
All Time: 13,158
