Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement
    1. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement, Asus Transformer Pad Infinity Teardown: step 1, image 1 of 1
      • First, turn the power off
      Ask FixBot
    2. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 2, image 1 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 2, image 2 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 2, image 3 of 3
      • Insert a small flat head screwdriver into the 2 docking station guide ports on the bottom of the tablet.
      • Unlock screen casing tabs
      • Push tab with screwdriver to the right until it clicks
      • You should see a small arrow in the bottom of the port
      • Unlock the tabs in both docking station guide ports.
      Ask FixBot
    3. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 3, image 1 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 3, image 2 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 3, image 3 of 3
      • Use spudger to push upward on the small plastic tabs on top of the docking station guide ports.
      • Insert the flat side of another spudger to start freeing the bottom of the screen from the case.
      Ask FixBot
    4. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 4, image 1 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 4, image 2 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 4, image 3 of 3
      • Use your spudger to open the four plastic tabs located on either side of the tablet.
      • These tabs are very fragile.
      • Remove the screen from the body
      Ask FixBot
    5. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 5, image 1 of 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 5, image 2 of 2
      • There is an internal power switch next to the battery connector, that will kill power to the entire device while you're working on it.
      • Don't forget to switch it back on when you're reassembling!
      Ask FixBot
    6. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 6, image 1 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 6, image 2 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 6, image 3 of 3
      • Use your spudger to release the two digitizer ribbon cables from the mainboard.
      • Located on the left side of the tablet between the micro-HDMI and the microSD slot.
      • Use your spudger to release the LCD cable from the back of the LCD.
      • Set aside for later dissection.
      Ask FixBot
    7. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 7, image 1 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 7, image 2 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 7, image 3 of 3
      • To remove the front facing camera (right):
      • Use your spudger to unlock the ribbon cable
      • Slide the camera out
      • To remove the rear facing camera (top):
      • Apply light lifting pressure to unplug it from it's socket
      • Remove the backup battery on the right side:
      • Unplug the cable from the motherboard with your spudger
      Ask FixBot
    8. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 8, image 1 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 8, image 2 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 8, image 3 of 3
      • Remove the motherboard, daughterboard, and dock connector
      • Unscrew 14 points
      • Unplug the speaker from the motherboard before removing it
      • Reveal the battery connector:
      • Flip the motherboard from the top edge of the tablet down (towards the battery).
      • Unplug with light pressure from your spudger.
      • Disconnect the motherboard from the daughterboard:
      • Unlock the ribbon cable on the back side of the daughterboard
      Ask FixBot
    9. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 9, image 1 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 9, image 2 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 9, image 3 of 3
      • Remove the battery:
      • Remove screws (eight)
      • Use your spudger underneath the battery between the 2 cells to work it free
      Ask FixBot
    10. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 10, image 1 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 10, image 2 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 10, image 3 of 3
      • Remove the speaker:
      • Use your spudger underneath, and work it free
      • Remove the bottom screen locking mechanism:
      • Lift pieces out
      Ask FixBot
    11. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 11, image 1 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 11, image 2 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 11, image 3 of 3
      • Now that we're left with a boring empty shell, let's return to the LCD assembly that we set aside in Step 5.
      • Remove the 4 screws. Then work your spudger underneath the edges of the LCD to separate it from the Gorilla Glass front. It has a light adhesive around all edges.
      Ask FixBot
    12. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 12, image 1 of 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 12, image 2 of 2
      • With the LCD free, you should now be able to lay it out in a big pile of parts and the teardown is complete. Now let's see what's under all those heatsinks and tape.
      Ask FixBot
    13. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 13, image 1 of 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 13, image 2 of 2
      • The back side of the motherboard
      Ask FixBot
    14. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 14, image 1 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 14, image 2 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 14, image 3 of 3
      • Motherboard backside closeups
      Ask FixBot
    15. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 15, image 1 of 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 15, image 2 of 2
      • The front side of the motherboard is where all the action is.
      • Tegra 3 quad core processor T33-P-A3
      • 2x Elpida memory J4216EBBG-GNL-F
      • Realtek? ALCS631
      • Hynix H26M64002BNR e-NAND
      Ask FixBot
    16. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 16, image 1 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 16, image 2 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 16, image 3 of 3
      • Front side motherboard closeups
      Ask FixBot
    17. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 17, image 1 of 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 17, image 2 of 2
      • Front and back of the daughterboard.
      Ask FixBot
    18. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 18, image 1 of 2 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 18, image 2 of 2
      • The back of the LCD.
      Ask FixBot
    19. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 19, image 1 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 19, image 2 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 19, image 3 of 3
      • Close-ups.
      • That's all I've got. I apologize for any blurry pics as all I had on hand was my cell phone ( <3 Samsung Galaxy Note.) I hope your teardowns are far less destructive than mine was. Good Luck.
      • ...and yes, it still works after reassembly. Thanks for asking.
      Ask FixBot
    1. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement, Rear/Front Facing Camera: step 20, image 1 of 1
      • Disconnect the camera connectors from the board.
      Ask FixBot
    2. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 21, image 1 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 21, image 2 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 21, image 3 of 3
      • Flip the pieces that secure the ribbons to the motherboard up. This is for the front facing camera.
      • Before removing the ribbon connectors, check for a release mechanism. Also make sure it is not a ZIF connector. Doing so can help prevent permanet damage.
      • Take out the ribbon connected to the motherboard. Pull the ribbon cable straight out of the soket to disconnect them.
      • Only follow what is needed for the camera you are replacing. If both cameras need replacement, do both steps. Otherwise, follow the one designated for the camera you need to replace.
      • The first photo shows the overall image. The second photo shows the step for the front-facing camera. The third photo shows the step for the rear camera.
      Ask FixBot
    3. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 22, image 1 of 1
      • Take the both cameras out of tablet.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Allison Poh
549 Reputation
5 Guides authored
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 32
All Time: 868
