Asus Transformer Pad Infinity LCD Display Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
12
Past 30 Days:
102
All Time:
1,762
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Introduction
Go to step 1 ↓
Replacing the LCD display involves opening up the device. Prerequisites; follow the Asus Transformer Pad Infinity Teardown link up to step 6 to remove the LCD display.
    1. Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: step 1, image 1 of 3 Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: step 1, image 2 of 3 Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: step 1, image 3 of 3
      • Disconnect the long silver ribbon connector from the screen.
      • Remove the orange ribbon connector with the two connections.
      Ask FixBot
    2. Asus Transformer Pad Infinity LCD Display Replacement: step 2, image 1 of 1
      • Remove the 4 screws around the metal portion of the screen (this is the LCD display).
      Ask FixBot
    3. Asus Transformer Pad Infinity LCD Display Replacement: step 3, image 1 of 1
      • Peel the orange ribbon back (it has adhesive sticking itself to the black electric tape looking stuff surrounding the metal portion).
      Ask FixBot
    4. Asus Transformer Pad Infinity LCD Display Replacement: step 4, image 1 of 1
      • Carefully place a preferably plastic tool between the glass portion and the electric tape looking stuff and pry off the screen from that portion.
      • Note: Take care as you’re dealing directly with with the glass and the way your touch input gets into the device.
      Ask FixBot
    5. Asus Transformer Pad Infinity LCD Display Replacement: step 5, image 1 of 1
      • Once removed, replace the LCD display back onto the glass screen (the new screen may or may not have new adhesive depending on where you got it.
      • If it doesn’t, make sure you secure it with the screws safely).
      Ask FixBot
Allison Poh
549 Reputation
5 Guides authored
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 102
All Time: 1,762
