Asus Transformer Flip Book TP200S Motherboard Replacement
    1. Asus Transformer Flip Book TP200S Motherboard Replacement, Battery: step 1, image 1 of 2 Asus Transformer Flip Book TP200S Motherboard Replacement, Battery: step 1, image 2 of 2
      • Remove the back 6mm and 8mm screws with a J000 screwdriver.
      Ask FixBot
    2. Asus Transformer Flip Book TP200S Motherboard Replacement: step 2, image 1 of 1
      • Remove the back cover of the flip book by gently using a metal spudger.
      Ask FixBot
    3. Asus Transformer Flip Book TP200S Motherboard Replacement: step 3, image 1 of 1
      • Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
      Ask FixBot
    4. Asus Transformer Flip Book TP200S Motherboard Replacement: step 4, image 1 of 2 Asus Transformer Flip Book TP200S Motherboard Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
      • Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
      • Gently remove the Wifi cables hooked to the rim of the battery
      • Remove the battery
      Ask FixBot
    1. Asus Transformer Flip Book TP200S Motherboard Replacement, Motherboard: step 5, image 1 of 3 Asus Transformer Flip Book TP200S Motherboard Replacement, Motherboard: step 5, image 2 of 3 Asus Transformer Flip Book TP200S Motherboard Replacement, Motherboard: step 5, image 3 of 3
      Buy
      • The motherboard has various components connected to it that you will need to disconnect to replace.
      • Disconnect the components from the motherboard with tweezers. Refer to the images for which components need to be removed.
      • The connections highlighted in yellow are easily removed by lightly pulling, If there is tape on it, simply remove the tape.
      • The connections in red require you to lift up the white latch securing these connections. The white latch lifts upward easily, afterwards simply slide out the connecting cable.
      • The connection in orange is similar to the connections in red, except the black part is the latch. Like before, flip it up and slide out the cable.
      Ask FixBot
    2. Asus Transformer Flip Book TP200S Motherboard Replacement: step 6, image 1 of 3 Asus Transformer Flip Book TP200S Motherboard Replacement: step 6, image 2 of 3 Asus Transformer Flip Book TP200S Motherboard Replacement: step 6, image 3 of 3
      • Unscrew the 3mm and 6mm motherboard screws from the device using a J000 screwdriver.
      • Remove the motherboard from the device.
      Ask FixBot
Alejandro Lopez
662 Reputation
5 Guides authored
USF Tampa, Team S17-G2, Boczar Spring 2018 Member of USF Tampa, Team S17-G2, Boczar Spring 2018
USFT-BOCZAR-S18S17G2
3 Members
60 Guides authored
1 Guide Comment
where can I get the board to buy??
Argent Logan - Reply Share
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 44
All Time: 3,466
