Asus Transformer Flip Book TP200S Battery Replacement
    1. Asus Transformer Flip Book TP200S Battery Replacement, Battery: step 1, image 1 of 2 Asus Transformer Flip Book TP200S Battery Replacement, Battery: step 1, image 2 of 2
      • Remove the back 6mm and 8mm screws with a J000 screwdriver.
      Ask FixBot
    2. Asus Transformer Flip Book TP200S Battery Replacement: step 2, image 1 of 1
      • Remove the back cover of the flip book by gently using a metal spudger.
      Ask FixBot
    3. Asus Transformer Flip Book TP200S Battery Replacement: step 3, image 1 of 1
      • Unscrew the battery from the motherboard using a J000 screwdriver on the 3mm screws.
      Ask FixBot
    4. Asus Transformer Flip Book TP200S Battery Replacement: step 4, image 1 of 2 Asus Transformer Flip Book TP200S Battery Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • The battery comes attached to the motherboard and needs to be disconnected before you can remove it.
      • Disconnect the battery from the motherboard by gently pulling out the connection with tweezers.
      • Gently remove the Wifi cables hooked to the rim of the battery
      • Remove the battery
      Ask FixBot
2 other people completed this guide.
Alejandro Lopez
662 Reputation
5 Guides authored
USF Tampa, Team S17-G2, Boczar Spring 2018 Member of USF Tampa, Team S17-G2, Boczar Spring 2018
USFT-BOCZAR-S18S17G2
3 Members
60 Guides authored
4 Guide Comments
how if my laptop not charge but the battery have replace before
Chen _El - Reply Share
its tooeasy! Thank You!
fotonngn - Reply Share
Its too easy! Tnks!
Where to find CMOS Battery?
Darwin Manliquid - Reply Share
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 102
All Time: 4,158
