Asus Transformer Book T100TAM-C1 USB Input Replacement
    1. Asus Transformer Book T100TAM-C1 USB Input Replacement, USB Input: step 1, image 1 of 1
      • Remove the tablet portion of the device from the keyboard by pushing on the silver button located at the base of the tablet and lifting up on the tablet.
      Ask FixBot
    2. Asus Transformer Book T100TAM-C1 USB Input Replacement: step 2, image 1 of 1
      • Use the plastic opening tool to remove both of the top corner pads.
      Ask FixBot
    3. Asus Transformer Book T100TAM-C1 USB Input Replacement: step 3, image 1 of 2 Asus Transformer Book T100TAM-C1 USB Input Replacement: step 3, image 2 of 2
      • Remove two 5mm Phillips #0 screws on the top corners.
      • Remove four 2.5mm Phillips #0 screws on the top corners.
      Ask FixBot
    4. Asus Transformer Book T100TAM-C1 USB Input Replacement: step 4, image 1 of 1
      • Use the pick and pry apart the keyboard.
      Ask FixBot
    5. Asus Transformer Book T100TAM-C1 USB Input Replacement: step 5, image 1 of 1
      • Use the size 0 Phillips screwdriver and remove the nine screws from the back panel. The four you need to remove across the top are 3mm and the four across the bottom are 2.5mm.
      • The screw in the top right, shown where the screwdriver is, is a 5mm screw.
      Ask FixBot
    6. Asus Transformer Book T100TAM-C1 USB Input Replacement: step 6, image 1 of 2 Asus Transformer Book T100TAM-C1 USB Input Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers and remove the black tape from the back panel.
      Ask FixBot
    7. Asus Transformer Book T100TAM-C1 USB Input Replacement: step 7, image 1 of 1
      • Remove the metal back panel from the keyboard.
      Ask FixBot
    8. Asus Transformer Book T100TAM-C1 USB Input Replacement: step 8, image 1 of 3 Asus Transformer Book T100TAM-C1 USB Input Replacement: step 8, image 2 of 3 Asus Transformer Book T100TAM-C1 USB Input Replacement: step 8, image 3 of 3
      • Flip the connectors back to release the wires
      • Take the white tab and gently pull it to the right in order to release the connecting piece.
      Ask FixBot
    9. Asus Transformer Book T100TAM-C1 USB Input Replacement: step 9, image 1 of 1
      • Remove the screw from the green plate.
      • Once all of the screws are out, remove the plate.
      Ask FixBot
    10. Asus Transformer Book T100TAM-C1 USB Input Replacement: step 10, image 1 of 1
      • Place soldering tool on each of the four connecting pieces in the corner until each becomes unattached.
      • Remove old USB input and replace with the new one.
      Ask FixBot
Brody Moore
813 Reputation
7 Guides authored
Ohio State, Team S1-G2, Whitney Fall 2018 Member of Ohio State, Team S1-G2, Whitney Fall 2018
OSU-WHITNEY-F18S1G2
2 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 25
All Time: 592
