Asus Transformer Book T100TAM-C1 Battery Replacement
  1. Asus Transformer Book T100TAM-C1 Battery Replacement, Back Panel: step 1, image 1 of 2 Asus Transformer Book T100TAM-C1 Battery Replacement, Back Panel: step 1, image 2 of 2
    • Remove the tablet portion of the device from the keyboard by pushing the large silver button near the base of the tablet. Pull up on the tablet to remove from the keyboard.
    Ask FixBot
  2. Asus Transformer Book T100TAM-C1 Battery Replacement: step 2, image 1 of 2 Asus Transformer Book T100TAM-C1 Battery Replacement: step 2, image 2 of 2
    • Insert the iFixit Opening Tool into the seam of the back tablet casing and gently pry upwards. With enough force the clips will release on the back tablet casing.
    • Make sure to insert the tool in the seam between the black and gray portions of the backing. If the tool is inserted between the screen and the black portion then the screen may crack.
    • Move the iFixit Opening Tool along the seam until the entire backing is removed.
    • Be careful and try not to use too much force while taking off the backing because you may damage the clips. If you damage the clips the backing will not fit properly back onto the tablet.
    Ask FixBot
  3. Asus Transformer Book T100TAM-C1 Battery Replacement, Battery: step 3, image 1 of 1
    • Carefully remove the copper tape at the top of the battery.
    • Save this piece of copper tape as you will need it for when you replace the battery.
    Ask FixBot
  4. Asus Transformer Book T100TAM-C1 Battery Replacement: step 4, image 1 of 1
    • Gently pull back on the yellow transparent plastic covering on top of the battery connection port.
    • The plastic covering is located at the top right of the battery, next to where the copper tape had been.
    Ask FixBot
  5. Asus Transformer Book T100TAM-C1 Battery Replacement: step 5, image 1 of 1
    • Insert the iFixit Opening Tool underneath the top of the battery and gently lift upwards to remove the battery.
    Ask FixBot
  6. Asus Transformer Book T100TAM-C1 Battery Replacement: step 6, image 1 of 1
    • Remove the battery from the tablet by slowly pulling it from the connected side.
    • The adhesive on the back will pull away from the battery.
    • The battery wire harness will come out as the battery is pulled up.
    Ask FixBot
Brody Moore
813 Reputation
7 Guides authored
Ohio State, Team S1-G2, Whitney Fall 2018 Member of Ohio State, Team S1-G2, Whitney Fall 2018
OSU-WHITNEY-F18S1G2
2 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 43
All Time: 1,327
