Asus Transformer Book T100TAF Motherboard Replacement
  1. Asus Transformer Book T100TAF Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Detach the screen from the keyboard using the silver button and pulling the screen in the upwards direction.
    Ask FixBot
  2. Asus Transformer Book T100TAF Motherboard Replacement: step 2, image 1 of 1
    • Pry the plastic backing off of the tablet using the plastic spudger, releasing all interior clips.
    Ask FixBot
  3. Asus Transformer Book T100TAF Motherboard Replacement: step 3, image 1 of 1
    • Unscrew all the silver screws from the motherboard
    • 3.0 mm (3) silver phillips head
    Ask FixBot
  4. Asus Transformer Book T100TAF Motherboard Replacement: step 4, image 1 of 2 Asus Transformer Book T100TAF Motherboard Replacement: step 4, image 2 of 2
    • Unscrew all the black screws from the motherboard with a PH00 screwdriver
    • 4.5 mm (4) black phillips head
    • 4.5 mm (2) black phillips head
    Ask FixBot
  5. Asus Transformer Book T100TAF Motherboard Replacement: step 5, image 1 of 1
    Tool used on this step:
    $3.99
    Buy
    • Detach the battery cable by steadily pulling it away from the motherboard with angled tweezers.
    Ask FixBot
  6. Asus Transformer Book T100TAF Motherboard Replacement: step 6, image 1 of 1
    • Gently pry the orange ribbon cable that is near the battery cable upwards with tweezers.
    Ask FixBot
  7. Asus Transformer Book T100TAF Motherboard Replacement: step 7, image 1 of 1
    • Remove the black strip along the top edge, releasing the two sets of connections.
    • Adhesive may hold this strip to the motherboard.
    Ask FixBot
  8. Asus Transformer Book T100TAF Motherboard Replacement: step 8, image 1 of 1
    • Use tweezers to detach the black and red twisted pair cable from its connection to the motherboard.
    Ask FixBot
  9. Asus Transformer Book T100TAF Motherboard Replacement: step 9, image 1 of 2 Asus Transformer Book T100TAF Motherboard Replacement: step 9, image 2 of 2
    • Detach the two thin black wires by grabbing them with tweezers.
    Ask FixBot
  10. Asus Transformer Book T100TAF Motherboard Replacement: step 10, image 1 of 1
    • With tweezers, gently flip the white clip up that is holding the white ribbon cable down. Pull the base of the white ribbon cable away from the motherboard with tweezers.
    Ask FixBot
  11. Asus Transformer Book T100TAF Motherboard Replacement: step 11, image 1 of 1
    • Disconnect the bottom orange ribbon cable with tweezers by pulling it away from the edge of the device.
    Ask FixBot
  12. Asus Transformer Book T100TAF Motherboard Replacement: step 12, image 1 of 1
    • Verify that cables are no longer attached to the motherboard.
    Ask FixBot
  13. Asus Transformer Book T100TAF Motherboard Replacement: step 13, image 1 of 2 Asus Transformer Book T100TAF Motherboard Replacement: step 13, image 2 of 2
    • Grab the motherboard with two hands, and gently lift it out of the device.
    Ask FixBot
4 other people completed this guide.
Danielle Nendza
209 Reputation
1 Guide authored
USF Tampa, Team 4-3, Passmore Fall 2016 Member of USF Tampa, Team 4-3, Passmore Fall 2016
USFT-PASSMORE-F16S4G3
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 28
All Time: 3,436
