Up to 20% off select tools
Asus TF300T Tablet Screen Replacement
Views: 23K
View statistics:
Past 24 Hours:
10
Past 7 Days:
26
Past 30 Days:
114
All Time:
22,650
Comments: 11
4 comments on steps, 7 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 18
18 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Difficult
Needs More Images
A few more images would make this guide's procedures crystal clear.
Parts
Tools
Introduction
Go to step 1 ↓
Replacing the screen on the Asus TF300T Tablet is a simple task by removing the back panel of the device to see the inside of the tablet. Once the inner workings are exposed the screen removal is a breeze with the use of the proper tools and knowledge.
    1. Asus TF300T Tablet Screen Replacement, Back Panel Removal: step 1, image 1 of 3 Asus TF300T Tablet Screen Replacement, Back Panel Removal: step 1, image 2 of 3 Asus TF300T Tablet Screen Replacement, Back Panel Removal: step 1, image 3 of 3
      • Begin the process by making sure that the dock is disconnected and the power is turned off.
      • Start by using the plastic opening tool on the side opposite the dock/ charging port. Begin to open the device along the short sides of the tablet.
      • When you have reached the side with the charging/ dock port be gentle with the opening tool due to the thinner plastic that could be broken with excessive force.
      • Once the opening tools have completely made their way around the device use the spudger to separate the back panel from the screen and expose the inside.
      Ask FixBot
    2. Asus TF300T Tablet Screen Replacement, Turn Off the Power: step 2, image 1 of 1
      • The Asus Transformer series tablets have a hard power switch. This should be turned off before working on the tablet.
      • Locate the power switch near the power button on the top left. Use a tool to slide it to the position marked 'off'
      • For many repairs, like replacing the screen or digitizer, you do not need to remove the battery once you hve turned the tablet off. Be very careful not to short anything out with metal tools!
      Ask FixBot
    3. Asus TF300T Tablet Screen Replacement, Battery Removal: step 3, image 1 of 3 Asus TF300T Tablet Screen Replacement, Battery Removal: step 3, image 2 of 3 Asus TF300T Tablet Screen Replacement, Battery Removal: step 3, image 3 of 3
      • Using the Phillips #00 screwdriver remove all of the screws connecting the battery to the mother board.
      • Once the initial screws have been removed as indicated by the photo, use the spudger to remove the cover concealing the the clips for the dock sensor and a few more screws.
      • Again remove the screws with the same screwdriver and use the spudger to disconnect the spudger sesors from their respective clips.
      • Once the battery is freed use the spudger to remove the battery from its spot
      Ask FixBot
    1. Asus TF300T Tablet Screen Replacement, Screen Removal: step 4, image 1 of 3 Asus TF300T Tablet Screen Replacement, Screen Removal: step 4, image 2 of 3 Asus TF300T Tablet Screen Replacement, Screen Removal: step 4, image 3 of 3
      • Remove the screws bordering the screen (Marked Red) using the Phillips #00 screwdriver. The screws holding the dock connector, the dock fixing points and the motherboard do not need to be removed. The screws attaching the digitizer board (left) do need to be removed, as do two screws accessed through holes in the motherboard.
      • Disconnect the digitizer cable.
      • The two connectors on the digitizer cable release by levering up the beige tabs on the back of the sockets. You may need to peel off the black foam blocks in order to remove the cable.
      • Remove the black tape (marked with yellow in the second image).
      • Lift up the digitzer control board and peel of the grounding tape from the underside of the SD card socket.
      • Disconnect the lvds connector from the screen (top left of the pictures). Peel the clear tape from the housing, and gently lever the connector out using the metal shoulders on each side of the plug.
      • Lift the tablet away from the screen assembly. The only thing still attaching it should be a small amount of grounding tape under the headphone socket (marked with purple on the second image.)
      Ask FixBot
      • Carefully measure the position of the screen withing the frame. You will need to place the new screen in exactly the same place, or the tablet will not fit back together.
      • Now using the heat gun or hairdryer on high, heat the edges of the screen in order to melt the adhesive holding the screen to the casing of the tablet.
      • When placing the new digitizer in the frame, you need to position it exactly. Do a dry fit without adhesive first, so you know how tight it has to be. The screen must press firmly into the rubber surround on all sides. If you place it loosely in one corner, the screen will not fit in to the other corner.
      Ask FixBot
12 other people completed this guide.
Author
with
Jonathan Barros
1,240 Reputation
5 Guides authored
UMass Dartmouth, Team 2-6, Duarte Fall 2014 Member of UMass Dartmouth, Team 2-6, Duarte Fall 2014
UMASSD-DUARTE-F14S2G6
4 Members
60 Guides authored
7 Guide Comments
The last picture is missing !
bjoerngollner - Reply Share
My asus tf300t power button only works once in a while. Can it be fixed?
michellegreenleaf51 - Reply Share
Can I change only the LCD screen? (my Touch screen I think that works ok)
Carlos Molina Ordóñez - Reply Share
That is this guide.
Heather Murphy - Reply Share
I followed all of these steps from a different guide with the exception of turning off the power switch (The other guide failed to mention this and i didn't see the power switch). I replaced the digitizer and reassmebled everything and the touch screen is unresponsive. I am not sure what to do at this point. I read around that maybe I blew a fuse by not powering off the switch. Any ideas? Thanks
ravensfh - Reply Share
Past 24 Hours: 10
Past 7 Days: 26
Past 30 Days: 114
All Time: 22,650
