Asus TF300T Tablet Front Facing Camera Replacement
    1. Asus TF300T Tablet Front Facing Camera Replacement, Front Facing Camera: step 1, image 1 of 2 Asus TF300T Tablet Front Facing Camera Replacement, Front Facing Camera: step 1, image 2 of 2
      • Disconnect the dock and make sure the power is turned off.
      • Use plastic opening tool to pry screen up and remove the main tablet body from outer rim casing.
      • Be gentle with the plastic opening tool near charging port. The thinner plastic may break easily.
      Ask FixBot
    2. Asus TF300T Tablet Front Facing Camera Replacement: step 2, image 1 of 3 Asus TF300T Tablet Front Facing Camera Replacement: step 2, image 2 of 3 Asus TF300T Tablet Front Facing Camera Replacement: step 2, image 3 of 3
      • Pull up on the black circuit board protector.
      • Turn off the hard power switch before working with the tablet. Use plastic tool to slide the switch to the position marked "off".
      • For most of the replacement operation, you do not have to remove the battery once you turned off the switch. Make sure that you do not short anything with the metal tools.
      Ask FixBot
    3. Asus TF300T Tablet Front Facing Camera Replacement: step 3, image 1 of 3 Asus TF300T Tablet Front Facing Camera Replacement: step 3, image 2 of 3 Asus TF300T Tablet Front Facing Camera Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Use a Phillips #00 Screwdriver to remove the six 3mm screws that connect the upper part of the motherboard.
      • Use tweezers to remove red connecting wires. Remove the motherboard by lifting it upward.
      Ask FixBot
    4. Asus TF300T Tablet Front Facing Camera Replacement: step 4, image 1 of 1
      • Use tweezers to pull out the gold flap connected to the front camera.
      • Pull the disconnected gold flap to take out the camera.
      Ask FixBot
Emma Sloan
101 Reputation
1 Guide authored
IUPUI, Team S2-G2, Wilson Summer 2017 Member of IUPUI, Team S2-G2, Wilson Summer 2017
IUPUI-WILSON-SU17S2G2
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 30
All Time: 680
