Up to 20% off select tools
Asus TF300T Tablet Display Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
100
All Time:
1,742
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Difficult
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
The display for the tablet is one of the hardest parts to replace as it is attached by glued and you will need a hair dryer. The broken screen affects the display's functionality and will need replacement.
    1. Asus TF300T Tablet Display Replacement, Display: step 1, image 1 of 2 Asus TF300T Tablet Display Replacement, Display: step 1, image 2 of 2
      • Disconnect the dock and make sure the power is turned off.
      • Use plastic opening tool to pry screen up and remove from outer casing.
      • Be gentle with the plastic opening tool when you reach the charging port as the thinner plastic could be broken easily.
      Ask FixBot
    2. Asus TF300T Tablet Display Replacement: step 2, image 1 of 3 Asus TF300T Tablet Display Replacement: step 2, image 2 of 3 Asus TF300T Tablet Display Replacement: step 2, image 3 of 3
      • Pull up on the black circuit board protector.
      • Turn off the hard power switch before working with the tablet. Use a tool to slide the switch to the position marked "off".
      • For most of the replacement operation, you do not have to remove the battery once you turned off the switch. Make sure that you do not short anything with the metal tools.
      Ask FixBot
    3. Asus TF300T Tablet Display Replacement: step 3, image 1 of 3 Asus TF300T Tablet Display Replacement: step 3, image 2 of 3 Asus TF300T Tablet Display Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Use a Phillips #00 screwdriver to remove the 3mm screws connecting the battery to the motherboard.
      • Use the same screwdriver to remove two 3mm screws connecting the clips.
      • Use tweezers to remove two wires connected from the battery to the motherboard.
      • Use the spudger to remove the battery from the case.
      Ask FixBot
    4. Asus TF300T Tablet Display Replacement: step 4, image 1 of 2 Asus TF300T Tablet Display Replacement: step 4, image 2 of 2
      • Use a Phillips #00 Screwdriver to remove the 3mm screws that connect the metal board with the screen.
      Ask FixBot
      • Use a hairdryer on high and heat the edges of the screen. Melt the adhesive holding the screen to the casing of the tablet.
      • Take out the display away from the screen.
      Ask FixBot
Author
with
Khairuz Zaki Md Rujhan
461 Reputation
3 Guides authored
IUPUI, Team S2-G2, Wilson Summer 2017 Member of IUPUI, Team S2-G2, Wilson Summer 2017
IUPUI-WILSON-SU17S2G2
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 100
All Time: 1,742
