Asus RT-N56U Disassembly
Views: 1.3K
View statistics:
Past 24 Hours:
6
Past 7 Days:
22
Past 30 Days:
105
All Time:
1,285
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
The Asus RT-N56U Wireless Router was released in Early 2011. It featured both 2.4GHz and 5GHz wireless networking, 2 USB 2.0 Ports, 4 Ethernet Ports, and a thin & stylish design!
Tools
  • Phillips #000 Screwdriver
    4.9
  • Spudger
    4.9
    Optional
    For prying off the front casing
  • Metal Spudger
    $2.99
    4.9
    Optional
    Alternative to a Spudger that may do some damage to the casing
  • Flat head Screwdriver
    $1.99 $6.99
    4.8
    Optional
    Another Alternative that I do not recommend but if you want to, and you don't want to buy a Spudger, go ahead, I warned you, not my fault if your router gets damaged.
    1. Asus RT-N56U Disassembly, Stand Removal: step 1, image 1 of 3 Asus RT-N56U Disassembly, Stand Removal: step 1, image 2 of 3 Asus RT-N56U Disassembly, Stand Removal: step 1, image 3 of 3
      • If the stand is slotted into the bottom, flip the router upside down and gently pull right to remove it.
      Ask FixBot
    2. Asus RT-N56U Disassembly, Peeling Sticker: step 2, image 1 of 3 Asus RT-N56U Disassembly, Peeling Sticker: step 2, image 2 of 3 Asus RT-N56U Disassembly, Peeling Sticker: step 2, image 3 of 3
      • Work carefully to peel the label on the back side off.
      • Try not to damage the label, as it can be important later.
      Ask FixBot
    3. Asus RT-N56U Disassembly, Case Screws: step 3, image 1 of 3 Asus RT-N56U Disassembly, Case Screws: step 3, image 2 of 3 Asus RT-N56U Disassembly, Case Screws: step 3, image 3 of 3
      • Unscrew the 2 Phillips screws securing the front casing in place.
      Ask FixBot
    4. Asus RT-N56U Disassembly, Plastic Clips & Adhesive: step 4, image 1 of 3 Asus RT-N56U Disassembly, Plastic Clips & Adhesive: step 4, image 2 of 3 Asus RT-N56U Disassembly, Plastic Clips & Adhesive: step 4, image 3 of 3
      • Remove the adhesive and clips also securing the front casing and lift it like a book from the left side, then remove it.
      Ask FixBot
    5. Asus RT-N56U Disassembly, Board Screws: step 5, image 1 of 3 Asus RT-N56U Disassembly, Board Screws: step 5, image 2 of 3 Asus RT-N56U Disassembly, Board Screws: step 5, image 3 of 3
      • Remove the 2 Phillips screws securing the main board to the casing.
      Ask FixBot
    6. Asus RT-N56U Disassembly, Removing the Board: step 6, image 1 of 3 Asus RT-N56U Disassembly, Removing the Board: step 6, image 2 of 3 Asus RT-N56U Disassembly, Removing the Board: step 6, image 3 of 3
      • Lift to around a 20° angle.
      • Gently pull up slightly, then the board should unlock to allow you to rotate it to around a 90° angle and remove it.
      Ask FixBot
afixer
201 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 105
All Time: 1,285
