Introduction
This is a comprehensive guide on replacing the battery in your Asus ROG Zephyrus G14 laptop. If your laptop can no longer retain a charge, it is probable that your dealing with a malfunctioning battery that needs to be replaced.
A properly functioning battery is responsible for supplying power to your laptop. As time passes and your laptop's battery undergoes numerous charge cycles, it may exhibit a quicker discharge rate. If you observe that your fully charged battery is depleting more rapidly than usual, it's advisable to perform a battery calibration to ascertain its true charging capacity. However, if you consistently experience substantial reductions in battery percentage, it's a clear indicator that it's time to replace your battery.
If you notice that your battery is swollen, take proper precautions. A punctured battery can cause a dangerous fire.
Before beginning, make sure that you power down your device.
Flip laptop so the back cover faces up.
Remove the ten (M2x10) screws.
Remove the three (M2x5) screw.
Loosen (M2.5x6) pop-open screw without removing screw from the cover.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
7 other people completed this guide.
1 Guide Comment
Replaced battery in 2025 but now it's dead. Clearly a bad battery. Can anyone suggest a good source for a reliable battery for this laptop?
