Asus ROG Strix GL702VS Motherboard Replacement
    1. Asus ROG Strix GL702VS Motherboard Replacement, Back Cover: step 1, image 1 of 1
      • Flip the computer so the bottom of the laptop is facing up.
      Ask FixBot
    2. Asus ROG Strix GL702VS Motherboard Replacement: step 2, image 1 of 1
      • Remove the ten JIS #0 screws around the edge of the laptop.
      • The two bottom screws are slightly shorter
      Ask FixBot
    3. Asus ROG Strix GL702VS Motherboard Replacement: step 3, image 1 of 2 Asus ROG Strix GL702VS Motherboard Replacement: step 3, image 2 of 2
      • Use a Jimmy to carefully free each side of the bottom casing.
      Ask FixBot
    4. Asus ROG Strix GL702VS Motherboard Replacement: step 4, image 1 of 1
      • Lift up the back casing from the computer.
      • You may hear clicking or snapping sounds. This is just the plastic clips coming loose.
      Ask FixBot
    1. Asus ROG Strix GL702VS Motherboard Replacement, Cooling Fans: step 5, image 1 of 3 Asus ROG Strix GL702VS Motherboard Replacement, Cooling Fans: step 5, image 2 of 3 Asus ROG Strix GL702VS Motherboard Replacement, Cooling Fans: step 5, image 3 of 3
      • Remove the four 4.8mm JIS #0 screws (two on each fan).
      Ask FixBot
    2. Asus ROG Strix GL702VS Motherboard Replacement: step 6, image 1 of 3 Asus ROG Strix GL702VS Motherboard Replacement: step 6, image 2 of 3 Asus ROG Strix GL702VS Motherboard Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the fan's connector on the motherboard using a pair of tweezers.
      • Be gentle, as the small clips and wires can be easily damaged.
      Ask FixBot
    3. Asus ROG Strix GL702VS Motherboard Replacement: step 7, image 1 of 2 Asus ROG Strix GL702VS Motherboard Replacement: step 7, image 2 of 2
      • Gently lift each fan up and out of position.
      Ask FixBot
    1. Asus ROG Strix GL702VS Motherboard Replacement, Motherboard: step 8, image 1 of 1
      • Disconnect the screen connector by lightly pulling the clip out.
      • The wires are delicate; disconnecting shouldn't take much force.
      Ask FixBot
    2. Asus ROG Strix GL702VS Motherboard Replacement: step 9, image 1 of 1
      • Remove the seven 4mm JIS #0 screws from the motherboard.
      • One may be hidden, requiring disconnecting the screen connector.
      Ask FixBot
    3. Asus ROG Strix GL702VS Motherboard Replacement: step 10, image 1 of 2 Asus ROG Strix GL702VS Motherboard Replacement: step 10, image 2 of 2
      • Unscrew the two 6.5mm JIS #0 screws located at the top corners of the motherboard.
      Ask FixBot
    4. Asus ROG Strix GL702VS Motherboard Replacement: step 11, image 1 of 1
      • Using the opening tool, lift up the flaps that secure the screen to the base.
      Ask FixBot
    5. Asus ROG Strix GL702VS Motherboard Replacement: step 12, image 1 of 1
      • Disconnect the Wi-Fi antenna by unplugging the black and white wires located behind the ethernet port.
      • For reassembly, note the corresponding triangles for each wire.
      Ask FixBot
    6. Asus ROG Strix GL702VS Motherboard Replacement: step 13, image 1 of 3 Asus ROG Strix GL702VS Motherboard Replacement: step 13, image 2 of 3 Asus ROG Strix GL702VS Motherboard Replacement: step 13, image 3 of 3
      • Use a spudger tool to lift the connector tabs on the motherboard and slide the four ribbons out.
      Ask FixBot
    7. Asus ROG Strix GL702VS Motherboard Replacement: step 14, image 1 of 2 Asus ROG Strix GL702VS Motherboard Replacement: step 14, image 2 of 2
      • Grasp the motherboard where the fans are located and lift up.
      • Do not force it. If you feel resistance, restart this guide to ensure you have removed all screws and connectors.
      Ask FixBot
To reassemble the device, follow these instructions in reverse order.
2 other people completed this guide.
4 Guide Comments
Any recommendation on WHERE to get a replacement mobo for this unit? Not having any luck in tracking one down.
help - Reply Share
Try ebay -- that's where I got mine.. arrived in a few weeks from China.
turgut kalfaoglu - Reply Share
What I wonder is that, when replacing the motherboard, should I remove all the aluminium tape that's at the bottom of the case? I suspect some of it has lifted and caused a short previously..
Yes I just replaced the motherboard. There are lots more tips that could have been added here but I used this page to remember where the screws are. Many thanks..
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 70
All Time: 2,381
