Asus ROG Strix GL702VS Fan Replacement
    1. Asus ROG Strix GL702VS Fan Replacement, Back Cover: step 1, image 1 of 1
      • Flip the computer so the bottom of the laptop is facing up.
      Ask FixBot
    2. Asus ROG Strix GL702VS Fan Replacement: step 2, image 1 of 1
      • Remove the ten JIS #0 screws around the edge of the laptop.
      • The two bottom screws are slightly shorter
      Ask FixBot
    3. Asus ROG Strix GL702VS Fan Replacement: step 3, image 1 of 2 Asus ROG Strix GL702VS Fan Replacement: step 3, image 2 of 2
      • Use a Jimmy to carefully free each side of the bottom casing.
      Ask FixBot
    4. Asus ROG Strix GL702VS Fan Replacement: step 4, image 1 of 1
      • Lift up the back casing from the computer.
      • You may hear clicking or snapping sounds. This is just the plastic clips coming loose.
      Ask FixBot
    1. Asus ROG Strix GL702VS Fan Replacement, Cooling Fans: step 5, image 1 of 3 Asus ROG Strix GL702VS Fan Replacement, Cooling Fans: step 5, image 2 of 3 Asus ROG Strix GL702VS Fan Replacement, Cooling Fans: step 5, image 3 of 3
      • Remove the four 4.8mm JIS #0 screws (two on each fan).
      Ask FixBot
    2. Asus ROG Strix GL702VS Fan Replacement: step 6, image 1 of 3 Asus ROG Strix GL702VS Fan Replacement: step 6, image 2 of 3 Asus ROG Strix GL702VS Fan Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the fan's connector on the motherboard using a pair of tweezers.
      • Be gentle, as the small clips and wires can be easily damaged.
      Ask FixBot
    3. Asus ROG Strix GL702VS Fan Replacement: step 7, image 1 of 2 Asus ROG Strix GL702VS Fan Replacement: step 7, image 2 of 2
      • Gently lift each fan up and out of position.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 87
All Time: 3,611
