Asus ROG Strix GL553VD Battery Replacement
Views: 6.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
30
Past 30 Days:
140
All Time:
6,635
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This is a simple guide on how to replace the battery in your Asus ROG Strix GL553VD gaming laptop.
Lithium batteries such as the one inside your gaming laptop deteriorate over time, losing their ability to hold a charge. This may not be a problem if you use your gaming laptop plugged in most of the time, but if you travel with your laptop and notice the laptop holding less charge and lasting for less time while on battery power, a battery replacement may restore some of the functionality of your laptop.
Happy fixing!
    1. Asus ROG Strix GL553VD Battery Replacement, Battery: step 1, image 1 of 2 Asus ROG Strix GL553VD Battery Replacement, Battery: step 1, image 2 of 2
      • Use a JIS screwdriver to remove the ten 4 mm screws from the bottom cover.
      Ask FixBot
    2. Asus ROG Strix GL553VD Battery Replacement: step 2, image 1 of 2 Asus ROG Strix GL553VD Battery Replacement: step 2, image 2 of 2
      • Open the flap in the middle to reveal the 11th screw and remove it using the same JIS screwdriver.
      Ask FixBot
    3. Asus ROG Strix GL553VD Battery Replacement: step 3, image 1 of 3 Asus ROG Strix GL553VD Battery Replacement: step 3, image 2 of 3 Asus ROG Strix GL553VD Battery Replacement: step 3, image 3 of 3
      • Gently lift each corner to remove the cover from the laptop.
      • If you seem to have difficulty removing the cover, you may use a plastic opening tool to pry up one of the corners to get you started.
      Ask FixBot
    4. Asus ROG Strix GL553VD Battery Replacement: step 4, image 1 of 3 Asus ROG Strix GL553VD Battery Replacement: step 4, image 2 of 3 Asus ROG Strix GL553VD Battery Replacement: step 4, image 3 of 3
      • Gently pull the white battery connector out towards the battery.
      Ask FixBot
    5. Asus ROG Strix GL553VD Battery Replacement: step 5, image 1 of 1
      • Carefully lift the battery out from the case to remove it.
      • The battery will come off easily as the screws are already removed.
      Ask FixBot
5 other people completed this guide.
Mahmoud Mehdi
271 Reputation
1 Guide authored
2 Guide Comments
Thank you for the guide. It was tricky to find the screw in the middle, hidden behind the flap. The screws are however not torx as shown.
Soheil Roshanbin - Reply Share
Hi,
Great job... quick and easy !
I've changed the battery of my ASUS ROG GL553VD but there is a problem... the battery doesn't charge and it is noticed a charge level at 255% in windows o_O Do you know if another action is needed ?
Aurélien F - Reply Share
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 140
All Time: 6,635
