Asus ROG STRIX GL502V Memory Replacement
    1. Asus ROG STRIX GL502V Memory Replacement, Asus ROG STRIX GL502V Lower Case: step 1, image 1 of 2 Asus ROG STRIX GL502V Memory Replacement, Asus ROG STRIX GL502V Lower Case: step 1, image 2 of 2
      • Remove 10 screws.
      • Note: front screws (blue) are 10mm long, central and rear (brown) are 12mm.
      Ask FixBot
    2. Asus ROG STRIX GL502V Memory Replacement: step 2, image 1 of 2 Asus ROG STRIX GL502V Memory Replacement: step 2, image 2 of 2
      • With opening tool or pick go around the case starting from back corner.
      Ask FixBot
    3. Asus ROG STRIX GL502V Memory Replacement: step 3, image 1 of 1
      • Lift cover and now you have access to most of the components.
      Ask FixBot
    1. Asus ROG STRIX GL502V Memory Replacement, Remove memory module: step 4, image 1 of 1
      • Pull spring locks out.
      • Lift module up and out of the connector.
      Ask FixBot
Sergei
650 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 76
All Time: 808
