Up to 20% off select tools
Asus ROG GL551J RAM Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
106
All Time:
2,232
Comments: 2
2 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace the RAM on your Asus ROG GL551J. Make sure that any new RAM has a DDR3 connection type to correctly fit into this device.
    1. Asus ROG GL551J RAM Replacement, Battery: step 1, image 1 of 1
      • Lay the device on a flat surface with the battery facing up.
      • Be sure to wear ESD or Rubber gloves to protect the computer components.
      Ask FixBot
    2. Asus ROG GL551J RAM Replacement: step 2, image 1 of 1
      • Push the latch found below the battery to the unlock position.
      Ask FixBot
    3. Asus ROG GL551J RAM Replacement: step 3, image 1 of 1
      • Pull the battery out.
      Ask FixBot
    1. Asus ROG GL551J RAM Replacement, RAM: step 4, image 1 of 2 Asus ROG GL551J RAM Replacement, RAM: step 4, image 2 of 2
      • Remove the two screws securing the access panel to the laptop.
      Ask FixBot
    2. Asus ROG GL551J RAM Replacement: step 5, image 1 of 2 Asus ROG GL551J RAM Replacement: step 5, image 2 of 2
      • Slide access panel out and remove.
      Ask FixBot
    3. Asus ROG GL551J RAM Replacement: step 6, image 1 of 2 Asus ROG GL551J RAM Replacement: step 6, image 2 of 2
      • Place thumbs on the locking tabs of both sides of the RAM stick and push outwards to unlock.
      Ask FixBot
    4. Asus ROG GL551J RAM Replacement: step 7, image 1 of 1
      • RAM should pop up at about 45 degrees. Pull outwards with fingers on the side of the RAM to remove.
      Ask FixBot
Congratulations, you now know how to replace the RAM sticks for your Asus ROG GL551J laptop, and this process can also apply to other similar laptops that you may acquire in the future.
3 other people completed this guide.
Author
with
Jason Nguyen
356 Reputation
2 Guides authored
USF Tampa, Team 5-4, Lacy Spring 2017 Member of USF Tampa, Team 5-4, Lacy Spring 2017
USFT-LACY-S17S5G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 106
All Time: 2,232
