Asus ROG GL551J Hard Drive Replacement
Views: 5.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
35
Past 30 Days:
121
All Time:
5,340
Comments: 3
3 comments on steps.
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Moderate
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
Use this guide to remove replace the hard drive in your Asus ROG GL551J, which can be completed in fewer than 3 steps.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Asus ROG GL551J Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Lay the device on a flat surface with the battery facing up.
      • Be sure to wear ESD or Rubber gloves to protect the computer components.
      Ask FixBot
    2. Asus ROG GL551J Hard Drive Replacement: step 2, image 1 of 1
      • Push the latch found below the battery to the unlock position.
      Ask FixBot
    3. Asus ROG GL551J Hard Drive Replacement: step 3, image 1 of 1
      • Pull the battery out.
      Ask FixBot
    1. Asus ROG GL551J Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 Asus ROG GL551J Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
      • With laptop upside-down, locate and unscrew the two screws on the panel with the vents.
      • Slide the panel out and lift up to remove.
      Ask FixBot
    2. Asus ROG GL551J Hard Drive Replacement: step 5, image 1 of 2 Asus ROG GL551J Hard Drive Replacement: step 5, image 2 of 2
      • The hard drive is the metal rectangle with the two soft padding bars attached to it.
      • Locate and remove the 4 screws holding the hard drive down at each corner using a PH000 Philips head.
      Ask FixBot
    3. Asus ROG GL551J Hard Drive Replacement: step 6, image 1 of 2 Asus ROG GL551J Hard Drive Replacement: step 6, image 2 of 2
      • Locate the black plastic tab attached to the bottom of the hard drive and pull it straight outwards.
      • Failure to correctly disconnect the hard drive before pulling it up and out can damage the connectors.
      • Once the hard drive detaches from the connector, lift the hard drive up and out.
      Ask FixBot
7 other people completed this guide.
Thien Vu
412 Reputation
2 Guides authored
USF Tampa, Team 5-4, Lacy Spring 2017 Member of USF Tampa, Team 5-4, Lacy Spring 2017
USFT-LACY-S17S5G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 35
Past 30 Days: 121
All Time: 5,340
