Up to 20% off select tools
Asus ROG G752V Keyboard Replacement
Views: 5.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
149
All Time:
5,328
Comments: 5
3 comments on steps, 2 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Difficult
Parts
Tools
Introduction
Go to step 1 ↓
If your Asus ROG G752V keyboard is no longer working, identify typical issues with Asus ROG G752V keyboards on our troubleshooting page. If the keyboard is needed to be replaced, this guide will walk you through the process.
Prior to beginning, ensure your Asus ROG G752V laptop is far from any dangerous materials, is no longer connected to its charger, and is powered down. Be sure to follow recommended tools and warnings included in this guide to prevent further damage to your Asus ROG G752V laptop.
    1. Asus ROG G752V Keyboard Replacement, Keyboard: step 1, image 1 of 2 Asus ROG G752V Keyboard Replacement, Keyboard: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • Make sure you disconnect the charger before starting this guide.
      • Using a pair of tweezers, remove all 11 rubber plugs off of the back cover.
      Ask FixBot
    2. Asus ROG G752V Keyboard Replacement: step 2, image 1 of 2 Asus ROG G752V Keyboard Replacement: step 2, image 2 of 2
      • Using a Phillips #0 screwdriver, remove all twelve 5.2mm screws on the back of the laptop.
      • There is one 5.2 mm screw under the rubber plug in the middle.
      Ask FixBot
    3. Asus ROG G752V Keyboard Replacement: step 3, image 1 of 1
      • Pull up the rubber seal and the service cover will come off.
      Ask FixBot
    4. Asus ROG G752V Keyboard Replacement: step 4, image 1 of 1
      • Using the Phillips #00 screwdriver, remove the six 5.2 mm screws under the service cover.
      Ask FixBot
    5. Asus ROG G752V Keyboard Replacement: step 5, image 1 of 1
      • Using your hands, pull the optical drive out.
      Ask FixBot
    6. Asus ROG G752V Keyboard Replacement: step 6, image 1 of 2 Asus ROG G752V Keyboard Replacement: step 6, image 2 of 2
      • Use the iFixit opening tool to pry apart the back panel from the main body of the laptop.
      • Start from the front side of the laptop and then continue to the side for easier access.
      Ask FixBot
    7. Asus ROG G752V Keyboard Replacement: step 7, image 1 of 2 Asus ROG G752V Keyboard Replacement: step 7, image 2 of 2
      • Slowly pull out the keyboard while lifting it about an inch.
      • There are cables attached to the keyboard and motherboard. DO NOT lift it more than 2 inches above the laptop.
      Ask FixBot
    8. Asus ROG G752V Keyboard Replacement: step 8, image 1 of 3 Asus ROG G752V Keyboard Replacement: step 8, image 2 of 3 Asus ROG G752V Keyboard Replacement: step 8, image 3 of 3
      • Using an ESD safe tool, detach all 3 ribbon cables. To do so, lift up the cable up and out.
      Ask FixBot
    9. Asus ROG G752V Keyboard Replacement: step 9, image 1 of 2 Asus ROG G752V Keyboard Replacement: step 9, image 2 of 2
      • Once the cables are detached, lift the keyboard about 2 inches up and remove it from the rest of the body.
      • Make sure that the screen is open like the photo. This will ensure that none of your laptop components will be bent.
      Ask FixBot
5 other people completed this guide.
Author
with
Jeong
1,227 Reputation
5 Guides authored
2 Guide Comments
That is not the "Keyboard" that is the entire top section or palm rest. Which also includes the touchpad and special function buttons. You should re name this as it is not accurate.
Doug Harris - Reply Share
boo hoo doug
Josephine Schroeder - Reply Share
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 149
All Time: 5,328
